Question about Acer Aspire 5610 Notebook
BIOS flash, wireless stopped
I have the aspire_5610z, and i just downloaded the bios update from acer.com but when flashed the bios, the wireless did not work at all.
i went to the vendor website but they ask for $39.00 but i'm not sure f that will fix it.
any one can help?
Acer aspire turns on but nothing on the screen
Hi;
This happened to me twice ( got two net books).
You need to follow up these steps:
Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
1.Go herehttp://support.acer.com/us/en/default.aspx and download the latest BIOS for the netbook.
2.Extract the files from the downloaded zipped BIOS file.
3.In the Dos_Flash folder, rename the BIOS file from 3310.fd to ZG5IA32.FD, in all capital letters.
4.Copy ZG5IA32.FD and Flashit.exe to the USB flash drive
5.Ensure that the AC adapter is plugged in.
6.Insert the USB flash drive into a USB port.
7.Press and Hold down the Fn and the Esc keys together and press the power button.
8.When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
9.After the keys have been released the power light will start to blink.
10.During the BIOS update process the display will be blank.
11.Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
If the unit fails to reboot, or the BIOS was not updated sucessfully, try the steps again. If the unit continues to fail to reboot, the unit may need service.
Good Luck
Sep 27, 2011 | Acer Aspire One A150-1006 Notebook
Aspire 5517 will not power up no lights, fans, nothing. Power supply checks OK
Hi:
1. Go here http://support.acer.com/us/en/default.aspx and download the latest BIOS for the netbook.
2. Extract the files from the downloaded zipped BIOS file.
3. In the Dos_Flash folder, rename the BIOS file from 3310.fd to ZG5IA32.FD, in all capital letters.
4. Copy ZG5IA32.FD and Flashit.exe to the USB flash drive
5. Ensure that the AC adapter is plugged in.
6. Insert the USB flash drive into a USB port.
7. Press and Hold down the Fn and the Esc keys together and press the power button.
8. When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
9. After the keys have been released the power light will start to blink.
10. During the BIOS update process the display will be blank.
11. Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
Good Luck
Sep 02, 2011 | Acer Aspire 5500 5570-2609 Laptop
My acer aspire one 532h-2db blank screen but the power is on. please help me! thanks.
Thank you for contacting Fixya. This is Anil.
I understand that the Netbook starts but there is not display on the screen.
It may happen due BIOS failure on the computer. Try updateing the BIOS. Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
Go http://gd.panam.acer.com/home/ and download the latest BIOS for the netbook.
In the Dos folder, Copy Flash.Bat; Flashit.exe; Nav50.fd to the USB flash drive
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you. Have Great Day.
Regards,
Anil.B.R
Jul 30, 2010 | Acer Aspire One PC Notebook
How do i update the bios on a acer aspire 4315 notebook? can anyone help??
Please follow the link mentioned below in order to update the bios.........
http://www.laptops-drivers.com/acer-notebooks/download-bios-updated-acer-aspire-4315.html
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 17, 2010 | Acer Aspire 4315 Notebook
Lap top went black and won't start
*This method only applies to Aspire ONE A150 only
1) Format USB memory stick with FAT file system.
2) Download BIOS for A150
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_3310_A_AOA110%20&%20AOA150.zip?acerid=633850493862245097&Step1=Netbook&Step2=Aspire%20One&Step3=AOA150&OS=X01&LC=en&BC=Acer&SC=PA_7
3) Extract all files the downloaded file and place FLASHIT.EXE and BIOS file onto the memory stick
4) Rename BIOS file to ZG5IA32.FD
5) Turn netbook of, with power AND battery connected
6) Plug in memory stick with BIOS file and Flasit.exe
7) Press and hold Fn+Esc the unit will go on, hold until power LED is flashing then release keys. If it does not flash, then release and press power button once.
8) You'll notice the LED of both the usb memory stick and the power LED will flash together.
9) After a few seconds the flashing will stop and the unit will reboot or switch off completely.
May 28, 2010 | Acer Aspire One PC Notebook
I turn my Acer on and nothing happens. The light
Try this it worked for me
  1. Go here and download the latest BIOS for the netbook.
Note: These instructions are only for the Acer Aspire One AOA-110 and the AOA-150 netbook series and should not be performed on any other model Acer Aspire One.
Mar 27, 2010 | Acer Aspire One PC Notebook
Bios laptop Acer Aspire 1360 is empty / broken after wrong flash
how come ur BIOS is empty....
did u FLASH ur BIOS with any firmware update....
Dec 20, 2009 | Acer Aspire 1360 Notebook
Battery will not charge
Power reset the unit, unplug it pop out the battery and hold the power down for a minute, put the battery and ac adapter back in and start her up, the mobo was probably still holding power when the battery died causing a "hiccup"in the system, this should resolve or at least help a little
Jan 23, 2009 | Acer Aspire One PC Notebook
Bios upgrade bios for aspire 5610z
If you go to the acer site there are utilities to update the bios
http://support.acer-euro.com/drivers/utilities.html#BIOS
Make sure 11% that you flash the correct bios as the wrong one will render it useless. Also make sure that you are plugged into the mains when doing it and pray that there isnt a power cut during the flash :)
Dec 26, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 Notebook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
