Question about HTC Touch P3450 Smartphone
Icontact by default on mi samsung omnia
I installed the icontact be (Burt Edition) on mi samsung omnia, i had no problem... but when i press the phone button on mi cel. the phone aplication by default in the omnnia appears....
I whish the icontact appears and not the omnia apps. phone.
Could you please give me a hand, I was reading that if i modified the HLOCAL CURRENT MACHINE (the registri) i will have the solutions.
Thanks
    President:
  • 1,223 Answers
Why dont u try modding ur phone menu i mean change it to SPB mobile shell and then u can change the soft key or just set the hardware key on the right of the PDA used for menu u can customize it in settings and make it go for icontact then when u press that key it will bring i contact , or u can google there is software for changing soft keys and hard keys , i will not suggest playing with ur registry
Posted on Feb 20, 2009
I m unable to allign the omnia screen
Hi user,
Omnia has a little bit of alignment options, in case you have made the setting change. The screen will be aligned as per your manual setting.
In case you want to realign the setting you need to set it up manually or you can do a default setting change in your mobile to get old default settings back.
This may change few other settings as well but atleast your screen will be aligned as it was earlier.
Best of luck!
Take some time and rate my suggestion.
Regards,
Richee
Jun 17, 2011 | Samsung SGH-i900 Omnia Unlocked Cellular...
I want to format my samsung B-7610 how to formate
hope this will help you:
Hard Reset - Samsung Omnia (i910)
A hard reset is the last resort for troubleshooting. This reset will erase all data and restore preferences to factory default specifications. Performing a hard reset is only recommended when the existing data has been backed up or is unwanted. If the preferred method is not available, there is an alternate Method.
Preferred Method
  • From the Today screen, tap Start > Settings.
  • From the System tab, tap Hard Reset.
  • From the Memory tab, tap Clear all data.
  • Tap Yes.
  • Tap the QWERTY keyboard icon at the bottom bar, enter the device lock code (the default code is the last 4 digits of the mobile number) then tap Yes.
Alternate method
  • Press and hold the Send key and the End key.
  • While holding down the keys, use the stylus to gently press and release there set button. Continue to hold down the keys until the Format screen is displayed.
  • Press the Send key to choose Format.
p/s: please do these procedures at your own risk. I will not responsible for any damage on your phone.
Thank you for using fixya..
Please rate me on fixya and provide testimonial if ever to continue my further assistance..
May 30, 2011 | Samsung Omnia Pro B7610 Smartphone
I want to change my i900 samsung 16 GB language to english
Hello thanks for using Fixya
To Change the language to English of Samsung SGH-i900 OMNIA. Follow the given instructions
1. First of all Download Samsung Omnia Operating System ZHHH2
2. Now hold your OMNIA in your hand Press the Dial key to the left of the optical pad to bring up the dialer. Keypad will open
With the onscreen keypad press *#1546792*#
Now Select "Preconfiguration"
Now enter code *#81230*# and select OK
Select "Hong Kong" with the default Operator
Accept this, DEVICE WILL HARD RESET
3. Now open i908ZHHH2_ENG from download folder which you have downloaded in step 1
4. Turn off the Samsung SGH-i900 OMNIA
5. Connect the OMNIA to a PC using the usb cable
6. Turn on the OMNIA
7. Click start button if the device found & wait for job done message
You have done it
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 22, 2011 | T-Mobile Samsung SGH-i900 OMNIA mit 16GB...
I forgot password of my touch screen samsung omnia
I think you'll have to hard reset your device, in order to get passed the password request procedure. You, most probably, know that a hard reset will return your device to its factory defaults, thus deleting all the applications you have installed, as well as all your personal data and settings. Anyway, to hard reset your device, press and hold both the SEND and END buttons, and, whilst keeping them pressed, press the reset pin with the stylus pen. Release the keys when a confirmation request screen comes up. Follow the on-screen instructions (if I'm not mistaken, confirm the hard reset procedure by pressing the SEND button).
Hope you are able to have a fully functional device again soon.
Best regards, Carlos
Jun 21, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
Need a passkey for samsung omnia
hi, default passkey is 0000. Enter this passkey in the asus notebook when it asks for passkey.
Both the passkey should be same to enable file transfer through bluetooth.
Sep 19, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Language change
Your Samsung Omnia (SGH-I900) supports only one default language. There is no way to add/change additional languages to your mobile phone.
Touch screen not work no response after i made hard reset
You may follow the steps below to reset it to default factory settings.
Hard Reset will reset your Omnia back to Factory Default. All contacts and information you have put on Omnia will be lost. Please backup before proceeding.
1. Poke the soft reset hole beside your power button(Poke and Release)
2. Press and hold the Call and Cancel Button together(Do it immediately after Step 1)
3. Do not release Call and Cancel button, the Samsung Omnia Screen Appear
Press Call to Format or End Call to Cancel.
This hard reset does not erase the 16GB memory. To reset everything, you could use the software hard reset by going to Settings > Hard Reset. There is also option to format the storage card.
If you decided not to format and press cancel, that will soft reset the phone.
Aug 23, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Hardreset samsung omnia i900
How to Hard Reset the Samsung Omnia Many people do not know how to hard reset the Omnia phone. The manual does not teach you the trick of doing this. You may follow the steps below to reset it to default factory settings.
4. The Reset Screen will appear as below
This is a snapshot of the Samsung Omina Reset screen.
(Image from mobilesilence.blogspot.com)
Another Method to Hard Reset
There is another method to Hard Reset, just key in the following code on your Dial Pad
*2767*3855#
After keying in the code, the Phone will restart itself. Phone will be reset to defaulf factory settings straight away. For DZIA5 Firmware, it will format the My Storage Card also.
Reference : taken from " pspmyspace "
Best Regards
Jul 08, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Change language of my omnia from Greek to English
hello,
In order to utilise english on your omnia you will need to download the omnia updater and then use it to install the english language ROM file. links below.
UPDATER-
http://www.mediafire.com/download.php?2ctayvcvex2
ENGLISH LANGUAGE ROM
http://www.mediafire.com/download.php?ne0nalozyy2
// j
Jun 25, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
How to change i900 language from Greek to English.
1 : Download & install latest version ActivSync 4.5 for XP ActiveSync 4.5
2 : Download samsung omnia os ZHHH2Z < full update Hong Kong English tested by me
3: Press the 'dial' key to the left of the optical pad to bring up the dialer
With the onscreen keypad input *#1546792*#
Select 'Preconfiguration'
Enter code *#81230*# and select OK
Select 'Hong Kong', with the default Operator
Accept this, DEVICE WILL HARD RESET<(credit goes to modaco forum Paul for this tips)
4 : open i908ZHHH2_ENG from download folder
5 : Turn off the omnia
6 : connect the omnia to a pc using the usb cable
7 : turn on the omnia
8 : click start button if the device found
9 : wait for job done massage
Originally posted by Ramjan from Bangledesh
Feb 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
HTC Touch P3450 Smartphone Logo
665 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
