Question about Kenmore Oasis HE 27082 Top Load Washer
Blue stains in the Kenmore Oasis
OK, we don't know if it is the washer or dryer.
We have the Kenmore Oasis washer and steam dryer. For the last several days, every load has come out with blue stains. I have run the washer through the clean cycle with bleach. The dryer tub is almost completely stained blue.
Is anyone else having this problem? I clean pockets before every load and none of the pants have the stains concentrated on them. It is just random on the clothes.
  • joe Feb 03, 2009
    my dryer is stained blue on the inside after 2+ years of owning it, but does not transfer the color to other articles of clothing. i'm guessing its from wet blue jeans with the hot steam causing it to transfer to the dryer?
    washer is not stained blue at all.
    haven't tried to clean it off since it wasn't a problem, but i will try this weekend just to see if i can get it off.
  • kwilkey Mar 12, 2009
    I have a 5 year old set of Whirlpool Duets. I seem to have the same problem with random blue "ink like" stains on random pieces of, usually, white items. I can't figure out if it is the washer or dryer causing the problem but it is VERY frustrating. My dryer is stained blue also and I initially thought this was due to wet jeans and hot air, but now I am beginning to become suspicious that this could be the culprit. Some please HELP us. I am sick of my clothes getting ruined.
  • 15,935 Answers
Check for a pen in the drain trap.
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
We have a Oasis Washer and Dryer with 4 hoses 1 is a Y trying to figure out how it all hooks up as we have only had 2 hoses in the past 1 for hot and one for cold???
If you purchased a steam dryer then the one hot hose hooks to the dryer. The cold hose goes to the washer. The hot hose from the valve goes to the Y then one hose to your washer and one hose to your dryer
Jul 11, 2011 | Kenmore Washing Machines
The Kenmore Elite Oasis Steam Dryer - almost new - worked well last week. This week no power to dryer; 220volts is present to dryer. Any ideas?
You might want to take a look at the vent pipe for lint. If the exhaust thernistor detects high temps it shuts down the dryer. Bravos service manual (same as oasis)
Apr 29, 2011 | Kenmore 67082 Electric Dryer
Since the new dryer was installed our home water
YOUR PROBLEM ISN'T WITH YOUR APPLIANCE ..CHECK YOUR WATER MAIN ON THE SIDE OF YOUR HOUSE...make sure it is open all the way..RDS
Apr 21, 2010 | Kenmore Elite Oasis ST 6806 Electric Dryer
I need the installation manual for a Kenmore Elite Oasis gas dryer. Specifically I need to know what water line attaches to the dryer (for steam), the hot or the cold?
Hello, Here's the link to view the owners manual and exploded view of the parts for your model. Once there, click on the exact model # you have (it's listed on your dryer's data plate) so you get the right one.
http://www.managemylife.com/mmh/owner_manuals/search?query=kenmore+oasis+elite+dryer+7808
Mar 09, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Blue stains on clothing
Brand New. Call for a warranty call asap. Should be no soap build up that quick.
Jan 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
105 people viewed this question
Sal De
fordexpert
Robert Rankin
