Question about Samsung ML-2510 Laser Printer
Printer keeps blinking
The printer still works but red light keeps blinking. What do I need to do?
  • NachEven Mar 09, 2009
    Same problem. Light blinks. Is there anything wrong?
I think its the toner low light, press the orange button to print a test page with diagnosis
Posted on May 15, 2009
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
On my HP F4180 the red light beside reume keeps blinking and I cannot print
Carriage jammed , check for that, if found any objects, remove to manually.if no objects observed might be service station strucked.. check it..If found difficulty, printer needs service..
Feb 02, 2012 | HP Deskjet F4180 All-in-One InkJet Printer
RED LIGHT KEEP BLINKING ON MY ML-2510 PRINTER IT STILL WORKS , WHY?
A red blinking light on a samsung printer will often indicate that your toner level is low. It will still continue to work until the toner fully runs out. This is Samsung's warning saying that you should think about changing your cartridge soon. I hope this helps.
Sep 08, 2011 | Samsung ML-2510 Laser Printer
My both red light is blinking continuously what i do help me
both light are blinking at the same time or blinking alternatively ?
if both blinking same time, it's a fatal error.. means it could be something wrong with the carriage or board or encoder belt...
if the light blink alternatively, it means the waste ink counter need to be reset and ink pad need to be replaced.
May 26, 2010 | Epson Stylus Photo R200 InkJet Printer
Both red light keep blinking
You need to reset waste ink counter. Use SSC Utility or R220/R230 Adjusment program. Find the software at indoreset.blogspot.com.
May 27, 2009 | Generic Memory EPSON STYLUS PHOTO R220 w/...
Red qoutation light keeps blinking/a440 print dock
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Office Equipment & Supplies
Red light ink cartridge keeps on blinking
what does it say next to the blinking light for example check paper, check ink cartridge, etc.?
tom
Dec 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
Blinking Red Light
unplug your printer
try to move the ink case manually.
if you could remove the ink cartridge, then clean the contacts both on the cartridge and case. return the cartridges then move the case to its original location
plug
Nov 06, 2008 | HP PhotoSmart 7660 InkJet Printer
ML-2510 mono laser printer / samsung
the answer is on:
fixyourownprinter.com
May 09, 2008 | Samsung ML-2510 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Samsung ML-2510 Laser Printer Logo
275 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
