Question about Averatec 6200 Notebook
Screen remains black on startup. Screen works fine in movie mode
Can watch movies, remote functions.
However, when starting computer-black screen only. Will not boot
  • 1 more comment
  • debbie_iselt Apr 17, 2009
    Same problem, same product. Stopped working march 6th. 10 days past the warranty
    Same problem, Same product. Stopped working 10 days after warranty expired
  • oscarrod73 May 04, 2009
    Same problem, mine stopped working about 6-7 years ago. and again warranty had expired!!!!
    i can play dvd movies but cant get it to get to post or get anything on the screen other than a black screen. urghhhhhhhhh
Black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Sep 19, 2013 | HP Pavilion dv6000z Notebook
I have a toshiba tv it's not a flat screen but its
If your universal remote has a video source select function, you should be able to use that as the aux(iliary) mode
Sep 07, 2013 | Televison & Video
Black rectangle appears on screen while trying to watch movie
This happens all the time, on your remote, go into the Menu and disable Closed Captions. It will go away after that.
May 01, 2009 | Sony DVP-NS575P DVD Player
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
How do I get to the ''Menu screen'' when playing a DVD movie?
It's likely the remote has the wrong code, so it will only work certain functions. You need to try lots of codes, if you do not know the player's code, till ALL function buttons work, not just some.
Aug 09, 2017 | Logitech Harmony 670 LCD Remote Control
Problem watching movies & playing games(screen flashes black on & off
HI
This may not help, but you can try to lower the resloution to another widescreen format.
I'm thinking you may have your resolution maxed out and the video card is having problems with the movie games because of that. Possibly not enough video memory
Movies will work fine at lower resolutions, Not sure about all the games but they probably will too.
Fran
Oct 15, 2008 | Computers & Internet
Sanyo dvd/vcr dvw 7000
I have a Sanyo Dvd/vhs player and I recentlty went to dish network instead of cable and I do not know how to get the player to work now so I can watch movies that I have rented. Can you tell me how to use the remote to watch movies.
Apr 08, 2008 | Sanyo DVW-7000 DVD Player/VCR
Sharp Aquos LC-32D43U
To adjust screen size, choose the View Mode feature on the top right of the remote control. Zoom size is full screen for watching DVD movies, but sometimes there is still a thin black band due to the formatting of the dvd (unless you buy full screen versions) S. Stretch view mode is best for TV Movies.(usually fills whole screen) Occasionally there are TV movies which just don't respond to being stretched to fill the screen, it's just the way the signal is coming through . 1080i/p detects the resolution of the signal and displays the same number of pixels on the screen, but a 720p signal input will be viewed in full screen.
Jan 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I just bought a ilo tv model dtv2794b and playing vcr's is ok but when i try to play dvd's i get big black lines on the top and bottom of the screen like i am watching a wide screen movie, there is a...
Most if not all DVD's are 16 by 9 even in 4.3 mode you are going to have those bars on this TV. Some television have a zoom feature to get rid of that but not this one.
Jan 14, 2008 | Televison & Video
Averatec 6200 Notebook Logo
120 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
