Question about Philips GOGEAR SA6045 MP3 Player
My philips 2gb wont turn on
The other day i had hooked my mp3 player to some kind of charger but afew hours later i came back and took it off the charger then it wouldnt come on.
  • 1 more comment
  • Anonymous Feb 04, 2009
    mine does the exact same thing!! it makes me angry it wont turn on even after several housr on the charger
  • Anonymous Feb 08, 2009
    mp3 not working
  • Anonymous Feb 09, 2009
    mine got so hot it burnd my fore arm
  • 8,596 Answers
All of your issues may be hardware-related - call Philips to see if you are still under warranty. To narrow it down, try this:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Feb 14, 2009
My gogear 4gb mp3 didnt come with a charger what kind of charger do i need
You could purchase the Wall Charger from :-
http://cgi.ebay.com/FOR-PHILIPS-GOGEAR-SA6045%2F37-SA5137%2F37-WALL-CHARGER_W0QQitemZ140370956787QQcmdZViewItemQQimsxZ20100101?IMSfp=TL100101011007r39882
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 13, 2010 | Philips GOGEAR SA6045 MP3 Player
My philips mp3 is not switch on
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Nov 27, 2009 | Philips SA4126/37 2GB MP3 Audio Player...
Cant turn my phillips pss110 after taking it out of the computer
does the device immediately shut off after displaying the Philips boot screen? if so, the mydb internal database file may be corrupt or missing.
Get the free program "ShoqBox Buddy" and use the "rebuild database" function to see if that fixes it.
Nov 03, 2008 | Philips PSS110/17 MP3 Player
Charging battery
you might have a faulty charger or the battery just won't charge , if you can exchange it back at the store I would do that , but otherwise the charger would have to be tested and the battery , and if those are ok then something is wrong in the mp3 player
Oct 12, 2008 | Philips GoGear SA2825/37 MP3 Player
Wont Play unless hooked to charger
Player can be reset from a lock up by pressing and holding "PLAY/PAUSE" and "Vol +"
Try updating the firmware with Device Manager on the product CD.
Jan 09, 2008 | Philips HDD082 MP3 Player
My philips mp3 help
same thing happened to me and i charged and it said to connect it to ur computer and it might work
Jul 09, 2007 | Philips HDD1630 MP3 Player
Zen creative mp3 player 2gb
Wrong product section, buddy
Apr 03, 2007 | Philips HDD082 MP3 Player
Wont Turn on
I had the same problem, I left it to charge (with just the backlight showing) for about 20 hours, and it just kicked itself back into life! If your's doesnt work after this, try the Philips support site, if you keep on at them enough, they do eventually do something!! Weedy
Oct 30, 2006 | Philips HDD065 MP3 Player
My Mp3 wont start up...
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Aug 02, 2006 | Philips GoGear HDD084 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
67 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
