''ilo lcd tv model lct42ha36 has elongated horizontal picture''
The picture is good in the center, left and right are stretched out.
  • 382 Answers
On the remote there is a settings button to set the screen paramiters.
Posted on Feb 02, 2009
    Genius:
  • 2,035 Answers
Try to change aspect ratio in tv if this did not help then ginko suggestion is right....
Good luck....
    Sergeant:
    Champion:
  • 289 Answers
Hi..there r various kinds of viewing available in ur
tv.In that if u see through the wide zoom option
ur picture will look good in the centre whereas in
both the sides it will be large.It looks like a cinema
screen.This is due to that wide zoom option.
In that case u view through normal option
which will show u in normal size.
thank u..
  • Hariharanath V Feb 09, 2009
    hi..
    Go to the view menu and change it.It will
    work out for you.
    try this out..
    thanks..
  • 19,396 Answers
That means that one of the convergence ics had blown.
  • Ginko
    Ginko Feb 02, 2009
    Sorry, my previous comment was for a different model, on your LCD there are no convergence ICs.
    However the video chipset on the LCD control board is malfunctioning, that is the reason for the distorsion on the picture.
    Try unplugging the TV for 30 minutes or so, to reset settings.
    Try also switching input channels, if the problem is only on a particular device, change device output settings.
    If you still have the problem you need to replace the LCD digital control board.
    You can find replacement LCD control for about $75 from link below:
    ILO Replacement TV Parts, Modules & Accessories
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
Looking for I-C in power suppy of ilo tv model no. lct42ha36 I-C is mc0628r . jhartley42@yahoo.com
Will never ever find IC alone,U lucky even find the whole power supply board .Tries Shopjimmy.com.Ebay.com for refurbish power supply board.
Jan 15, 2010 | iLO LCT32HA36 Television
Who is the manufacturer of the ILO 26HD Television?
the manufactured should be on the back of the tv- i have an ilo 27 flat lcd hdtv the name on the back is
SUPERIOR ENTERPRISES
5900 CANOGA AVE
WOODLAND HILLS CA 91367
Mar 15, 2009 | iLO 2600 Television
My sony tv problem is that the picture is stretch horizontally..
If you have a DVR too, there is a pound (#) button on the beside the zero on the DVR remote that stretches my screen off and on. Try that.
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
ILO TV
push the "Pic Size" button and make sure it is not on Panoramic, that setting stretches and warps the right and left side of the picture
Oct 22, 2008 | iLO 3200 32 in. LCD Television
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
Black marks
I am getting a black cloudy mark on the right side of the screen. It's not even on the part where a Wide screen picture would be, it starts at the wide screen area and gets darker going to the left towards the center. The TV is just over a year old. It's Wal-mart POS Ilo brand.
Dec 19, 2007 | iLO 3200 32 in. LCD Television
42" ILO Television Problem
same here model lct42ha36 for less than 90 days some say you can take it back to walmart, hurry. you can call ilo at 800-216-5156 with model and s/n and they will give you a number for akai 800-428-1105 or tatung 888-428-1105 to call depending on which made it. I called akai and they had me fax a copy of receipt and the transaction number they gave me to set up a in home repair by a service center at no cost they say (i hope) it is cover for one year parts and labor and you can go back within 90 days and buy extended warrenty for 2 more years for about $60. I'm over 90 days so i'm going through the process. Repost to this site and let me know how it goes. I'll repost if I can with a follow up when they come out.
Oct 05, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
