Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigerator too cold
We had ice storm and without power for 2 days, now back on and cannot get refrigerator side of Kenmore Elite to stabilize....it is too cold staying at 10 degrees, followed manual instructions in booklet to no avail. How do we get the temperature back up to around 33 degrees?
  • 218 Answers
Sounds like the damper door that regulates airflow from the freezer into the fridge is staying wide open. The cause could be a bad thermostat or a failed damper motor, but it could also just be ice jamming the mechanism. That could have happened after a two-day opportunity to melt and re-freeze, so let's try a cheap troubleshooting method first.
Look in the fridge for the plastic grill where air comes from the freezer into the fridge - probably down low on the partition wall. Aim a hair dryer, on a medium heat setting, into the grill for a minute or so and see if that helps. There's a fan in there, so don't go poking your fingers in unless you unplug the fridge first.
If this doesn't help, then you may have a failed component in the damper door assembly, or possibly a bad thermostat. Good luck with this, and I'm glad your power is back on!
Posted on Feb 02, 2009
What would be the problem if refrigerator become a freezer.......all my vegetable and stuff that should stay cold become frozen ....I have a Kenmore elite top mount refrigerator which I bought 5 years...
this can happen when your ice can start to block vents ...try turning off your fridge for 2 days so any ice blocks that have formed can melt right down , then switch back on ....should do the trick
Oct 19, 2010 | Refrigerators
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Cream In Freezer Is Soft
DON'T BY ICE CREAM! LOL Try putting ur ice cream somewere else
Oct 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is cold, but not the refrigerator
I think you will find ice built up in the inside back panel of you freezer and the temp inside your freezer is not cold enough. Should be from 0 to -10 . Is so, you have a defrost problem. You can take the panel off and defrost the coils with a hair dryer. You then can inspect the heaters. You can then replace the panel and the fridge will operate normally for two or three days. This will give you time to get the part or have someone to fix without loosing you food.
Please rate this solution if helpful.
Aug 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not cold - freezer fine
ice buildup will most likely block the air flow.
if so the air will not be able to enter fridge section. Check air vent in fridge side if you can hear the fan and get no air flow then its blocked - common defrost thermostat failure.
to temporarily clear the problem just use a hair dryer on the ice build up area
Aug 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Jul 20, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
167 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
