Question about Ricoh Aficio CL3500N Laser Printer
Ricoh c3000 replace fuser error
Tried all of that....still no go...anything else/
  • 2 more comments
  • tonerink Feb 02, 2009
    after replacing the fuser still give "replace fuser" on the display. all menu buttons are locked....hmmm
    chris
  • Juanita Vega
    Juanita Vega May 11, 2010
    have you tried to reset it?
  • Juanita Vega
    i would try to replace it again and see what happens
  • Juanita Vega
    is it giving you any error messages?or what is it doing?
  • 3 Answers
I am not sure if you can, but I had this issue too.
Go to the menu key. Use arrows to find "maintenance" and press enter.
Use arrows to go to Maint. reset and press enter.
Use arrows to display fusing unit and press enter.
It will tell you to press # - press enter.
If that doesn't work, you may also want to try pressing and holding the escape button for 5-10 seconds and it will reset itself.
Posted on Feb 13, 2009
4 Suggested Answers
vegakitten20
  • 685 Answers
SOURCE: Ricoh c3000 replace fuser error
try to unplug it from the wall and plug it back in and let me know if this works
Posted on Feb 02, 2009
SOURCE: Part Number for RICOH Aficio MP C3000 Fuser Unit
Part number is: B237 4053 (North America)
B237 4054 (Europe)
I Expect this will be very expensive as it is not designed to be replaced as an entire assembly, but rather repaired as needed.
Posted on Feb 23, 2009
  • 3 Answers
printer error fuser temp.
Posted on May 27, 2009
Ricoh mp c3000 colored copies are double print
Could be drum units there are 4 drums or fuser assy. since you said color only I said drum unit try scanning a single color see which one does it . Will need to call a copier company or go online and buy a whole photoconductor . You will need to know how to initialize unit before you put it in.
Jan 14, 2014 | Ricoh Aficio 1018 Printer
Copier Gestetner Dsc530 (or Ricoh Aficio mp c3000) has error SC501 - tried to reset, but need to replace thermistor. Can't find a diagram on where it's located on the fusing unit. Anyone?
Error code SC501 is not a fuser problem. It is the top paper feed tray. Take all of the paper out of tray 1 and turn the machine all the way off. Turn it back on. Code should be cleared. If it returns with no paper in it the paper feed station has a broken part and can only be repaired by replacing it.
Nov 04, 2013 | Gestetner Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Part Number for RICOH Aficio 1022
The fuser part number for a aficio MPC 3000 isB2374053 USA
and B2374054 for EU
Jun 01, 2009 | Ricoh Aficio AP2000 Laser Printer
B237 4054 (Europe)
Feb 23, 2009 | Ricoh Aficio AP2000 Laser Printer
Feb 02, 2009 | Ricoh Aficio CL3000 Laser Printer
Service error 0544 on a Ricoh Fax 5510L
Hi there the error you have is that the fuser unit is lower than 130 degrees for 1 minute. Suggestion replace fuser unit turn power off the on. If problem still persists replace control board or power board.
Thanks Jason
Jun 26, 2008 | Ricoh FAX5000L Plain Paper Laser
Ricoh Aficio CL3500N Laser Printer Logo
439 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
