Question about Carrier TSTATHCP Programmable Thermostat Air Conditioner
Electric immersion heater keeps cutting out
I have an electric immersion heater (now 3 years old) in the bathroom. Recently it has kept cutting out (by tripping the fuse) after quite short intervals - so the fuse may need to be reset several times before the water is hot enough to have a shower. Any ideas on how to fix this?
  • 56 Answers
Sounds to me like you have a bad thermostat. You should be able to give a model number to any local plumbing supply place and get one for replacement. make sure power is of the unit before replaceing.
Posted on Feb 12, 2009
My hot water heater is 6 yrs old should i change the elements or replace the water heater
Replace elements and thermostats
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Check the anode rod
http://waterheatertimer.org/Replace-anode-rod.html
If anode is replaced, then tank will not rust.
This maintenance will keep electric water heater is good operating order indefinitely.
You never need to replace electric water heater if water pressure is kept below 80 psi, and anode is good and keeps tank from rusting.
Nov 20, 2012 | Water Heaters
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I needto know if my water heater has heating elements
unless it is solar it will have either a gas element for gas heaters or electric element for electric heaters. presumming it is electric, the element is an immersable element mounted in the bottom of the tank. when the electrical cover is removed you will see the 4 bolts that hold it in place.
Mar 15, 2011 | Rheem Water Heaters
Ge electric water heater. 3 years old. keep tripping reset. both elements show 13 ohms, with no gronding out condition. help!
Have you replaced the thermostat they will short out and keep tripping to they go bad. Check the ends of the elements also for any bad places. Ran along this a few times and it ends up being a bad thermostat causing it to trip. You will reset it and it may last a day or more and keep resetting it and eventually it will short out or burnt out. So please check it out and this helps you.
Mar 13, 2011 | General Electric Water Heaters
I purchased a perko urn model #107Sss and the water has a terrible metalic taste. What can i do
I bought the same horrible, cheap, dishonest unit. They disingenuously say to rinse and boil once. I've boiled the water at least twelve or thirteen times. They also brag it doesn't need immersion (not because such units don't require immersion since that will damage the unit and they don't need immersion) but because of their superior spirituality. Let them answer for dishonesty in 120 years.
Jun 06, 2010 | Le Chef Electric Shabbos Hot Water...
My electric water heater is 4 years old. It has
Your expansion tank is probably bad, it devoloped a leak, and lost it's charge. The replacement of the tank should solve the problem. Hope this helps
Jan 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hot water heater flow problems.
hey Bookie, those plastic inserts are kinda moulded into the nipples, so taking them out might be more than a feat,...did you solder the pipe to the female adapter ON the nipple? if you did you melted the plastic and that is what's your restricting your flo,......or (believe it or not) the inlet water valve isn't turned on all the way,.....close it then open it,..could have somethin stuck in it. let me know eh? thanks and good luck, cracklin joe
Jan 05, 2010 | General Electric GE SmartWater Household...
Toro electric trimmer motor keeps stopping
Very possibly a bad switch or loose wire.
May 17, 2009 | Toro& Electric Trimmer
Electric Water Heater Using Too Much Electric.
Maybe you want to think about getting a tankless heater.The gad unit works real good.But the electric water heater i want to think you should check the thermostate.Maybe it is struck and not cutting off every time.
Mar 13, 2009 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Heating & Cooling Logo
469 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
