Question about RCA F25441 25" TV
Picture Problem The top 2/3rd of the screen is black with distorted lines. Next is part of the actual picture in a 2-3 inch line across the screen, then the rest is the black distorted lines. The entire screen flashes and fluctuates and the picture changes on the screen. Purchased the TV in Apr. 03. It first did this at the beginning of last year for a couple of days, then worked fine until now.
  • dreefer Feb 28, 2009
    exact same as the first post my tv is only using about 1/3 of the screen to show the picture. I think I can fix it with some more detail in the answer. please help if you can!
    President:
  • 2,992 Answers
This is a problem (one of several) caused by poor solder connections on the circuit board. RCA uses the metal shield can surrounding the tuner circuitry (the area where the cable connector is located) to provide several ground connections. Many of these connections go bad (cracks form) and the missing ground connections cause the "picture shrinking" you see. Other problems are loss of tuning, set that intermittently turns off or on by itself, set that won't turn on at all, and even more.
The repair involves removing the circuit board and flipping it over so you can remove a metal cover on the bottom, repairing the several (many) affected connections, and then reassembling. This is a relatively easy repair for someone with soldering experience and the right tools (both a high-heat soldering gun and a low-heat iron are needed). But because of the fragile circuit traces in the repair area it is possible to do more harm than good if you don't know what you're doing.
RCA produced a service bulletin several years back detailing the areas to be repaired (although they still refused to admit they just hadn't soldered the places adequately to begin with). I'm not home now so I can't check my files but I'll see if I can find a link and add a comment later. When I was in the service business we charged around $60 for the repair. You might want to get an estimate from a shop (they should already be familiar with this trouble). Or if you're looking for a reason to buy a new set, try the repair yourself. If you're successful you've saved yourself the money. If not, it wasn't working anyway!
Posted on Feb 02, 2009
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
No picture
hi, the problem is in the vertical ossilation.. let me know
Dec 18, 2007 | Sansui DTV2760 27" TV
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
RCA F25441 25" TV Logo
126 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
