Question about Polaroid FCM-0700A 7 in. Portable Television
Unit is completely dead
On this unit you have to use the DVD option to play CD's which turns on the screen to a blue screen. We were listening to a CD and when the player finished it was left on for at least 24 hours without playing anything, just in the on position. The next day I noticed the clock was out and thought the breaker may have tripped. It didn't and the outlet is working fine. When I plug the power cable in to the wall a red light is lit on the AC addpter, then when I plug it into the TV set the red light turns faint and blinks. The TV acts like it is not getting any power. Do I have a bad adapter or is the TV shot?
  • Anonymous Apr 06, 2009
    Called Polaroid, they told me the motherboard is dead. I didn't even have to explain the situation, they know these are junk. They offered to send me a refurbished one if I pay the same price I paid for new one.
    Genius:
  • 2,035 Answers
Is the adapter getting hot ,then you replace the adapter else you can check the o/p of the adapter with help of multimeter it read 12 volts ,if it reads 12 then there is problem with tv itself..
Good luck...
Posted on Feb 02, 2009
DVD bypass code for Jensen VM9216BT
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote,
listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/
screwdriver on it in the upper left-
hand part of the screen.
5: Select Brake bypass to "ON" and hit
the "X" near the bottom of the screen. There is the code.
Jul 16, 2013 | Jensen VM9216BT 7" Touch Screen DVD, MP3,...
When playing cds in my sony cdxgt500 the sounds come throught the door and rear speakers fine, but not through the subs. everything works as it should while playing the radio.
Hello.... it sounds like you have the remote wire for the amplifier hooked to the solid blue wire behind the radio. You need to hook to the blue/white wire behind the radio. What happens is that the solid blue wire turns on the power antenna when you are listening to the radio and it turns off (lets the antenna down) when you listen to a cd. There should be a blue/white wire that is the amplifier turn on wire that will stay on as long as the head unit is on. Hope this helped!
20 year car audio/video installer
Bay manager
Apr 06, 2011 | Sony CDX-GT500 CD Player
Have just reinstall windows vista, and then evyrtthing is fine unless i want to play a cd or dvd, cause the icon of cd/dvddevice in m computer is missing and therefore cant play any cd/dvd..in device...
Try to right click on CD/DVD name from Device manager and verify that it is enabled (if you can see an Disable option then it is enabled, if you see an Enable option click on it).
Anyway try to disable/enable the CD/DVD unit from device menager and in Windows Explorer press F5 to refresh the screen.
Apr 10, 2010 | ASUS M51Sn-C1 Notebook
The DVD-VCR unit won't accept any DVD - blank or with content. It says "LOAD" but then ejects the DVD. Same DVD works in an identical Samsung unit in another room.
You may have a dirty lens on the DVD read head. There are CD/DVD cleaning kits available at some drug stores and electronic stores. Do not get a "CD cleaning kit" (that only cleans the discs), get a "CD/DVD lens cleaning kit" (it will have a special CD and cleaning solution) for $10 to $20.
If that's not it the DVD illumination LED may be dead. If it still plays CDs, but won't play DVDs, that's the problem. There are separate LEDs for playing CDs and DVDs.
Either way, if the cleaning doesn't work, it has to be fixed in an electronics shop.
Oct 06, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Overhead DVD monitor screen dead but sound plays through stereo
If it's a Rosen dvd player the dvd will need to be put in the unit itself & not the unit in the dashboard! The dvd player mounted in the head ligning is a seperate unit from the stereo system fitted in your dashboard!
Sounds to me like you are putting a dvd into the dashboard stereo system which will play any audio through the car speakers...
Put a dvd into the Rosen unit itself & i am sure you will get a picture on the drop down screen! Remember that as far as i know all Rosen dvd players transmit the sound from the dvd to infra red headphones that should be included! Remember to check the batteries if you still can't hear any sound as they run down quick if the headphones are left on!
Hope this helps....
Apr 08, 2009 | Rosen A7 Car DVD Player
Kenwood kvt m700- playing cds
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
Mar 27, 2009 | Kenwood KVT-M700 Car DVD Player
Jenson VM9311TS will not play all speakers in cd mode
YES!! You used the blue wire to turn on factory amp (blue wire to GM pink) you NEED to use the Blue/White wire. That is the amp turn on. The blue wire goes dead when you play a CD or DVD because it's for a power antenna. So, Blue/White ok?
Enjoy,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Jensen VM9510 Car DVD Player
RCA DVD/VCR model DRC8320
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
My phase linear uv7i can't plays dvd's or cd's and the screen is totally blue
caution it´s unlawful to operate a vehicle while video is dispayed in thr drivers viewing area
engage emergency brake sequence to enjoy video???? help help please
Jan 26, 2008 | Phase Linear UDV9010 Car DVD Player
Jensen head unit VM9311TS no sound from CD
Should wire HU's Power Const to Amp's Remote On. Instead you wired HU's Power Antenna to Amp's Remote On. So the stock amp got triggered only in radio mode.
Jan 24, 2008 | Jensen VM9020TS Car DVD Player
Polaroid FCM-0700A 7 in. Portable Television Logo
162 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
