Question about GCC Technologies Elite 12/1200N Laser Printer
Error message "servicer reqired 10"
I own Elite 12/1200. Recently the printer began to jam the paper on the feed and give error messages "service required 10", but after restarting the printer it printed again. But today it keeps giving the same message with paper feed jam, and after restarting or cartridge replacement it does not work and gives the same message. Knowledgebase gives little insight into the problem and eventually states that I have to bring the printer to the authorized technician. I live in Armenia and unfortunately there are no such technicians for GCC printers here, and also I cannot call on the phone. Please explain me how can I overcome the problem. Sincerely yours Khachik Grigoryan
  • Anonymous May 06, 2009
    I have same problem from 4-5 days! I need this printer. I tried to e-mail d_atwood@gccprinters.com but I din't get answer. Please help me, becouse I don't know what to do. I can't ask service for halp, becouse I live in Poland and here isn't tech support.
    Regards
    Krzysiek
    Problem Solver:
  • 5 Answers
Please email to d_atwood@gccprinters.com for a solution. Mention the error message # 10
Posted on Apr 28, 2009
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
C4180 HP PRINTER GIVING ME AN ERROR MESSAGE OF "CLEAR PAPER JAM , THEN PRESS OK." THERE IS NO PAPER JAM.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Aug 18, 2010 | Office Equipment & Supplies
Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
Jan 30, 2010 | Epson STYLUS R350 Photo Printer
The printer is not feeding paper but still gives the E3 error message
If paper has jammed in the machine,clear the jam reload the paper in the machine correctly and then press black or color key.If you are not success so it is problem mechanical.Service it and solve your problem.
Nov 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
3 yellow flashes, then 1 green on a Canon PIXMA Ip4000
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
Sep 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
LSU error message
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Paper jam message, but actually no paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Mar 08, 2009 | Lexmark X2350 All-In-One InkJet Printer
Paper Jam
because of your paper sensor is not working or jam
Feb 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
GCC Technologies Elite 12/1200N Laser Printer Logo
183 people viewed this question
Top GCC Technologies Office Equipment & Supplies Experts
jasbo
jasbo
Are you a GCC Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
