Question about Dell 5100cn Laser Printer
Dell 5100cn laser printer
Wanted to ask if a Dell 5100 is a Xerox, or Fuji printer, have a problem where developer will not drive looks like black toner is locked up, also may have damaged clutch on gear drive for developer. Cannot get solid answer from Dell on part number for developer gear drive assembly. They gave me a part number for the motor, but could not say if it was with the gear drive or not.
  • 49 Answers
Yes, Dell Color Laser 5000 series printers are Xerox printers. Good luck finding the part....
Posted on Feb 27, 2009
My dell printer 5100cn , print quality very light, replaced inks drum and still having problem with black
laser printers have a high freq high voltage wire that puts ions on the paper as it passes ,
have you cleaned this wire . it attracts dirt an inks like the paper it treats.
there is a wire cleaning tool in the machine usually.
Jan 04, 2015 | Dell 5100cn Laser Printer
Developer drive assembly
That's what you need a developer drive assembly, I've replaced several of these with exact issues. After replacing the part printer prints color.
May 10, 2010 | Dell 5100cn Laser Printer
Please can someone help me to get the service manual for the Dell laser 5100cn printer (.pdf) Thank you
The dell 5100cn is a rebranded Xerox Phaser 6300. You can buy the maintenance manual for under $4 on ebay. I did, and it was emailed to me as a pdf.
Apr 24, 2010 | Dell 5100cn Laser Printer
Printing noises - no ink transferring
Sounds like you may need to replace the developer drive assembly. This is the motor and gear assy that drive the color developers. it is located on the right side middle, 3 screws hold it in place. be careful when replacing to not over tightened screws.
Apr 09, 2009 | Dell 5100cn Laser Printer
Dell 3110cn color laser prints with black "haze" on all pages
You probably used a "GENERIC" toner cartridge on one of your toners.
This caused the developers to get contaminated, now they need to be replaced (probably Black & Blue)
Jan 12, 2009 | Dell 5100cn Laser Printer
56Tbird
not a problem at all.
This should fix your issue. I won't say it is a common failure, as the machine overall is very reliable, however for this problem the magenta developer is the most common failure for the 5100 and 5110.
Check your email shortly for the document and additional comments.
Please take a moment to rate this solution,
Thanks,
Cory
Nov 05, 2008 | Dell 5100cn Laser Printer
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
Dell 5100cn printer
The only effect that the "non Dell toner" setting has is to raise the fuser temperature to the maximum. Since all toners are made up of ink and plastic, the fuser is what melts the fine plastic to the paper.
Dell toner is designed to melt at a lower temperature, however, since the non dell toners temperature value is unknow, this setting allows for that unknown.
In any case, neither of these things will cause lite, or faded print. In Fact, the toner cartridge for this model is actually nothing more then a toner storage device. Some cartridges contain the toner, the developer, and the drum. On the 5100 and the 5110 this is not the case.
The photo developers are located behind the imaging drum. you can see the 4 seperate developers, in the developer frame, when you remove the drum unit.
More then likely, if only the black is printing poorly, and the colors are printing ok, then the black photo developer is defective. This is a very messy job if you do not know what you are doing, and very involved.
You need to remove the top cover, the left side cover, the high voltage power supply, the supply tubes ( where the toner travels from the actual toner cartridges down to the developers ). Then once the tubes are removed, you have to remove the developer frame from the printer. Then you can get to the actual photo developer.
Good luck.
Aug 22, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Problem
My Dell 1600n suddenly stopped printing. It keeps saying "No paper," and even though I've changed papers, fanned it, squared it, changed how much, how little.............it still says "no paper."
Dec 27, 2007 | Dell 5100cn Laser Printer
Dell 5100cn seeing red
dont know if this helps but the dell 5100 is a rebadged xerox 6250,maybe you can find a manual for that one easier.
Nov 09, 2007 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
234 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
