Troubleshooting intertherm feh-015ha (FROM FREEZING FAMILY)
My furnace just blew a fuse and when i replaced the fuse(s) the furnace still didn't come on. First, it's a new breaker. Second, i've already tested for power and it's got power. I'm leaning towards the sequencers or transformer. I don't know how to diagnose them though.
  • 4,655 Answers
Having changed the fuse and breaker tell me there is a major short in you furnace. 240 volts is a lot of amperage and a very delicate job to attempt to help you directly. I have found that any intertherm dealer near you will be happy to help solve your problem. Yes, the sequencers are possible reason but 50 amps at 240 volts is what concerns me. Did your transformer burn out also?
Let me know what you think and if you would like, I will locate the correct source of help. Thanks, JT
Posted on Feb 03, 2009
York affinity 9.s series, year 2008. I have not used my furnace since last winter (approximately 7 months ago). I went to start it up this year for the first time and it will not start. Upon inspecting...
Fuses will blow if there is an overload.
Breakers only trip if there is a short to ground.
Since you replaced the fuse and it blew and tripped the breaker , I would check for a wire problem. Also check the elements that rodents haven't built nests ect...
Nov 12, 2014 | Heating & Cooling
New belt very adjusted, motor is stop, that i do?
Check if it possibally has a fuse that blew. If not the motor is probaly burnt out, Or all so check that your plug is good, Or that you didn,t kick off a breaker or fuse in your power box.
Oct 25, 2012 | Washing Machines
Blew a fuse that operates radio, clock and all the electronics adapters, need to know which fuse works these?
My access to Suzuki diagrams does not indicate the functions of the fuses, it only gives me what they look like. Best thing to do is to have a meter to test the fuses and relays and whichever one tests bad, take that to the auto parts store to match it up. Most auto parts store will order you the correct fuse/relay if they do not have it in stock.
Jan 05, 2012 | 2003 Suzuki XL-7
Hitachi 57f500a e907 fuse blew on the power supply board, replaced e907, and it went again. Is this a problem on the power supply board or the deflection board? Where should I start looking next?
If QH01 is shorted again, then this is an indication that the FBT is already faulty causing QH01 to shorts right away and blew E907(self destruct when shorts occured on the line). 100VDC isn't causing E907 to blew, you've only got 100VDC because the FBT didn't oscillate yet. Before you replaced the FBT make sure to test all parts parallel on the B+ line like DH09, Q701, CH16, CH13, CH20. It is better to pull-out the FBT while testing the shorted/leaky parts on the board to make your reading more accurate. If you found the said parts to be in good condition, then you have to replaced the FBT.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Nov 03, 2011 | Hitachi 57F500 57" Rear Projection...
Fuse blew on bernina 180 artista sewing machine advised to go up to a 5 amp fuse blew another part now has a small burn hole in it Please refund my $30 I may need a new circuit board
Herein is a lesson to very firmly learn .... fuses are rated for a reason .... NEVER, EVER put a bigger fuse in if the last one blew, because it blew for a reason. A fuse is there to protect your equipment from damage and for your safety ... if you put a bigger fuse in and your equipment gets damaged as a result, you've only yourself to blame. Just be thankful it didn't burst into flames and if you think I'm being dramatic ... dont ... fuse 'abuse' is one of the biggest causes of house fires. Whoever 'advised' you to do this wants his/her ears bashed and if you paid money for this advice, you desrve it all back plus the cost of repairing the damage it caused !!!
Jul 31, 2011 | Bernina Artista 180
My aprilaire 700 isn't coming on (no water flow). The front part of the unit has fallen off the furnace twice (held on by plastic nubs/slots...) and blew the furnace fuse/ and circuit breaker probably...
Check for voltaged at the solenoid valve. This will either be a 24 volt or 110 volt solenoid valve. Confirm power into the unit 110 volts. If you have power into the unit and no voltaged at the solenoid valve on a call for humidification at the humidistat than the circuit board or the step down transfgormer has failed.. If you do have voltage at the solenid valve than the valve has failed.
Jan 26, 2011 | Aprilaire 700 Humidifier
Bulb blew on cooker hood and I replaced both. Light still won't work and neither will fan - both working fine until bulb blew.
hello. I can assist you. begin by going to the electrical panel for your home. You will be looking for the circuit breaker or fuse that controls this hood. Chances are the actual problem is that the fuse blew, or the circuit breaker kicked off. To reset, replace the fuse with a new one of the same amperage, or turn the breaker on and then off and then back on again.
Nov 18, 2009 | Televison & Video
2002 GMC wiring problem
get one from junk yard sounds like a dead short somewhere check around starter wires!!! :)
Jul 06, 2009 | 2002 GMC Yukon XL
Neither fan or compressor will com on
You have a short circuit in the system at some point. A blown fuse on the circuit board indicates a short in the control circuit. Tripping of the breaker indicated a high voltage draw from the compressor. Check the compressor motor terminals with the wires removed and the power off. Use an Ohm meter from a terminal to ground. You should have no reading. If you have any reading the compressor motor is shorted out and the compressor is done.
Jun 17, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
789 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
