Question about NEC Electra Elite DTU 16D-2 Corded Phone
How to program a key for headset?
We have a NEC 770012 8 button phone that I need to program on the call keys to a headset key. Does give me instruction on how to do this?
  • 63 Answers
This is done in system programming.
Posted on Feb 07, 2009
I plug in a headset correctly put the speaker button still goes to loudspeaker and not to the headset? Is there a setting I need to change?
You need to program a headset key on one of your buttons. Likely your vendor has to do that, unless you have an in house system manager who is really capable.
Mar 28, 2015 | NEC DTL24D1BK Phone
How do I get my headset to work on NEC SV8100
to use the headset port you can program a button that toggles between the handset piece and the headset port (under the handset),
assuming that your installer has used standard feature codes, press the following;
? Press Speaker key.
? Dial 751.
? Press an available Function key. (one of your unused 24 buttons)
? Dial 05.
the Function button is now your Headset pickup/release button
Feb 26, 2015 | NEC Lands Phones
I have a NEC Dterm80 I need to program a button on the phone to be my handset button so I may be able to use my handset. I dont what to have to call a DeltaCom tech in to program.
First and foremost we need to know what system you have. Then we can proceed with how to program the button.
NEC Elite 48, 192, IPK 1
First pick the button you want to program. Lets say button 13 in this example. Next check to see if that button is programmed by pressing Feature and that key. If that key says Vacant then it is available for use.
Next you will need to hit "Feature and 4" on that station to find the port #. Port # is Tel 10 for example. That means port 10 is where your extension resides.
Now type in "Feature, #, 0 *, 8974". The phone should say Program Mode. Now look at the Line Keys. These are the keys right above the # pad. Count from left to right 4 keys. Hit Line Key 4 and then type 12 on the dial pad.
Now that we are in key programming we need to enter the port of your phone. Make sure the blinking cursor is on the far left. If not press * to move to the left. Now enter 10 (port 10 or Tel 10) on the dial pad. The cursor should be right near the L. If not then press # to move to that position on the right. Remember * will bring you back to the left and # to the right.
This is where you are to enter the key #. In our example it is key 13. Dial 13 on the dial pad. Next we are going to change the key to a headset key by pressing "Recall, Line key 3". It should say H Set on the right. Now that you have the proper key set you need to hit transfer to write the programming. Remember to try and find a key that is not programmed, this will ensure that you don't undo any programming that is already in place.
Any other system other than the NEC 48, 192 or IPK 1 will not work.
Nov 17, 2009 | NEC Dterm DTP 16D-1 Corded Phone
I am buyind a gn2020 headset with amp I am looking for the code
you need to program headset keys on the phones if you have headset jacks on them. This is done in key data memory block 4-12 for each phone and than choose which LK(line key) once on the right line key hit the line keys on the phone and you will see different thigs like CO, FA, ICM, just hit them all till you see headset. Transfer key writes the data and the recall key turns the pages so the line keys will say something different. or call tech support ldtsnj.com
Jul 07, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Hi I cannot get the headphone set to work with the NEC Dterm 80 phone. Headphone model is Compucessory 55251. Thanks very much.
you need to program a headset key on the phone in memory block 4-12 for that extension. You can assign a line key as a headset key to make the headset port on your phone usable. ldtsnj.com
Need the steps to program the user defined buttons
go into program mode, find the port number of the telephone and in memory block 4-12, input the button number and browse difference Lk key to look for H_SET. Press transfer to save.
Jun 02, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Headset on DTU 8D-2 corded phone
If you are using the headset jack on the phone, a headset key needs to be programmed on the the phone. You can do this in program mode and make a line key a headset key. Otherwise you must connect it through the handset. ldtsnj.com
Aug 26, 2008 | NEC DTU 8D-2 Corded Phone
NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Jun 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Connect/Program Headset
Sure you can do it. as long as the headset has a plug for the handset your fine. Plug it in and you will have to pick up and hang up the handset as needed. The headset key eliminates you having to pick up and hang up the handset to answer with the headset.
Feb 21, 2008 | NEC DTU 8-1 Corded Phone
I need to program a HeadSet Button
For the DTU phone on an NEC Elite system:
Memory Block 4-12
put in the port number and the Lkey of the extension you want to make a headset key.
Programmin on a 16button phone, Lkey 11 needs to be lit and will display H SET to verify.
For the DTP phone, it is generally on an NEC 2000, which is entirely different.
Oct 12, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
373 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
