Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto Rapid Steam Espresso machine is dead. no power. The outlet in the kitchen does work- I did check that. I read a couple of threads about removing the back and resetting fuses but I cannot find the fuses to reset...
  • Anonymous Feb 09, 2009
    this is weird - the same day you posted this I got the same problem - maybe saeco build this machine with a time bomb in it?
They are not fuses, they are re-settable thermostats and are quite hard to find, you have to remove the top and back of the machine along with the lower black rear plastic panel. The 2 thermostats are located on the heating block, bottom rear left hand side (when facing front of machine) Both will need re-setting, press each t/stat firmly between the 2 wires of each one and a distinct click can be heard when you press them.
Posted on Jan 03, 2010
  • lambjean Aug 28, 2011
    Thanks for this help .... you have saved our beloved machine from the dump! Incidentally this Saeco Machine goes under the Tchibo name in the UK, but I recognised it from the pictures.
  • khleech Dec 11, 2014
    It's several years later but this advice is still spot on. Just saved my 9 year old machine with this fix. 15100 cups and going strong.
Saeco S class Incanto Classic was working, but now no steam at all. The pump sounds like it is trying to pump, but cuts out after a coupl of seconds, hot water light comes on, red water light flashes, and...
Check the end of the steam wand and parnello, if both are clear, then descale machine, that might unblock the tubes feeding the booster boiler and the steam wand if it doesn't then you will have to do it manually.
Mar 06, 2010 | Saeco Incanto Classic Espresso Machine
Machine won't prime
Try lifting the water tank, then setting it back in place, and then priming the machine.
Jan 15, 2010 | Saeco Incanto Classic Espresso Machine
Saeco incanto rapid steam leaking from under
The leak is most likely from the steam valve, you will have to either buy and replace the o-rings and the pistons in the valve or just buy a new valve assembly and replace it. Easiest solution get the new valve assembly.
Jun 25, 2009 | Saeco Incanto Classic Espresso Machine
No power to Saeco Incanto Rapid Steam
If you have a round boiler on your machine, then you have two automatic fuses on the right side of the boiler close to the chassis, there are wires going to these fuses and in the middle of the fuse you have a plastic pin you have to press down, you have to these on both fuse.
If you not have a round boiler then you have a wire with a black holder, the wire mostley have a blue color.
Best regards
/Mirran
Feb 02, 2009 | Saeco Incanto Classic Espresso Machine
Saeco incanto rapid steam Model #SUP 021yr
Try to clean the brewing unit and make sure the filters is clean.
/Mirran
Aug 21, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Saeco Coffee Machine Type SUP 021YDR Display shows Ventilate when I follow instructions and turn the Hot Water and the water knob the water is not coming through....
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 12, 2008 | Saeco Incanto Classic Espresso Machine
Brand new Incanto Classic bought online, not working after 1 month
First, machine should be under warrantee- check with 1800myjuicer.com
Sounds also like you have blockage in the steam wand- every time you froth milk, you should let some water come out- to prevent clogging. Try first inserting a pin into steam want ( machine turned off) to see if that alleviates the problem. Also contact
Saeco USA Inc.at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 17, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
491 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
