Question about Ricoh Aficio CL3000 Laser Printer
Ricoh c3000 replace fuser error
I can't get the error to clear after replacing the fuser. The menu is locked down. Is there a reset for this?
thanks
chris
  • tonerink Feb 03, 2009
    I found the reset for this...hold the escape key down while powering up for at least 5 seconds!!!
  • 685 Answers
Try to unplug it from the wall and plug it back in and let me know if this works
Posted on Feb 02, 2009
How can i reset the code error sc543 for kyocera fsc1020mfp
To enter the maintenance mode menu use the following procedure:
1. Turn the main switch ON.
Take the following steps in sequential order.
2. Press "Clear/Stop"
3. Press "1".
4. Press "0".
5. Press "7".
6. Press "Color Start".
The LCD display will show "Maintenance Mode".
With the up or down key find the Engine Maintenance and press OK. Then with the keys search for Fuser SC Reset and press OK. The fuser error will be resetted.
Also in the same menu (Engine Maintenance) you' ll find and this one option Replace Fuser (Resets the maintenance counter for the fusing unit.This item appears only when the fusing unit life is almost expired or has expired.)
Oct 02, 2014 | Kyocera Office Equipment & Supplies
Kyocera 2050 errore code c6000 problam
Error C6000 is a fuser error.
Solution 1:
  • Turn it off
  • Wait 5 minutes
  • Turn it on and the code will be clear.
Solution 2:reset the fuser
  • First open top cover then turn on power.
  • press system menu/counter
  • arrow down to service
  • press and hold start, # then enter keys
  • arrow down to maintenance
  • press enter
  • arrow down to Sim 163
  • press enter
  • select execute
  • press enter
  • turn off power then back on
Solution 3:
  • You need to replace the fuser
Sep 25, 2013 | Kyocera Office Equipment & Supplies
C6000 code
Solution 1:
  • Turn it off
  • Wait 5 minutes
  • press enter
  • press enter
  • select execute
  • press enter
Solution 3:
Sep 25, 2013 | Kyocera Mita KM-2050 Printer
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
Replace fusing unit error
Can you put the old fuser back, just to see if the message clears.
Mar 04, 2010 | Ricoh Aficio AP3800C Laser Printer
I have an x543 Lexmark printer and there is an error message, I have not been able to clear; 122.05 Service - Fuser Error Any help?
i have an x543dn has a fuser error of 122.03 service fuser error, i just reset the factory defaults in the config menu and it cleared that error, to get to the config menu press and hold the tick button and the right arrow next to it then power up the machine and continue holding these until the menu is displayed then scroll through menu until you get to factory defaults select this then select reset base, hope this helps. Kev
Jan 08, 2010 | Lexmark T632 Laser Printer
Need to clear the error code "replace Fuser" Fuser is new and so is the paper tray cannot seem to get the darned thing to clear
Put the MFC into Maintenance Mode
Press the Menu and Start Keys at the same time then press the up arrow key 4 times the machine should display "Maintenance " in the LCD display
Press the 8 key twice, Display should show Part Replacement
Press up or down keys to select "Reset Fuser" press OK or Start Key to reset the counter of the fuser
To Exit Maintenance Mode press the 9 Key twice
I hope this helps.
Aug 20, 2009 | Brother MFC-8460N All-In-One Printer
Error code C 6400
This code is a fuser problem code. Follow the procedure below. If the code does not reset or comes right back then: you will have to check the thermistor, thermo fuse and fuser lamp. If 1 or more are defective then replace. After you replaced the defective part you will have to clear the error code again.
Here's the way to reset that fuser code;
press enter
press enter
select execute
press enter
Jan 27, 2009 | Office Equipment & Supplies
Resetting lbp fuser
you need to do a lbp fuser reset and lbp error log clear
fuser reset
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, then press 7- start- down arrow - start- then yes
log clear
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, the press 6 - use the down arrow to get to lbp log clear.
if this does no work you need the fuser replaced
good luck
Oct 12, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
Ricoh Aficio CL3000 Laser Printer Logo
308 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
