Question about Hotpoint TDC32 Electric Dryer
Tdc32 tumbler dryer will not heat up to dry clothes
  • 547 Answers
Replace heating coil
Posted on Feb 11, 2009
DRYER HAS NO HEAT. TUMBLER TURNS OK. LINT FILTER CLEAN.
Make sure the dryer exhaust tube is clear of lint and not kinked. Next thing I would check are the thermal fuse and thermostat. Check this out: http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
May 05, 2015 | Washing Machines
Dryer sounds like it is drying properly. It feels warm to the touch as if it is drying properly. However, the clothes inside are not being heated at all. What part would I need to fix it?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 25, 2011 | Hotpoint TDC32 Electric Dryer
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
Tdc32p condenser dryer has low heat only
It could be, also is the condenser taking the water out ok into the drawer, if not they could be a blockage in the pipes and a pump underneath the dryer may be blocked or faulty.
this could be the cause also.
Sep 14, 2009 | Hotpoint TDC32 Electric Dryer
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Dryer takes 3 times to dry
My tumbler won't turn on my front load Kenmore dryer
Mar 07, 2009 | GE Dryers
Hotpoint vtd65 dryer good working but not drying cloth
You will find the heater and stats located behind the removable panel at rear of dryer, you will need a meter to test them for continuity. there are other possibilities for it not to heat, so do not assume it is a faulty heater.
Plz rate my solution.
Thankyou.
Jan 22, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius ctd40
most likely, there is a blockage in your exhaust. take it apart and check every inch from your dryer to the outdoors. i clean mine once a year, it keeps the dryer running efficiently. when lint backs up in there, the heat cannot get out and there is a sensor that will shut off the heating element when it gets to a certain temp, so your clothes will take a long time to dry
Oct 27, 2008 | Hotpoint TDC32 Electric Dryer
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
Hotpoint TDC32 Electric Dryer Logo
126 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
