Question about Coleman 10' X 10' Sundome Tent 9160K101
I need an operator manual for a Coleman DGAA 070 BDTB furnace
Operator and install manual for a Coleman DGAA 070 BDTB propane furnace.
2 Suggested Answers
  • 21 Answers
SOURCE: I need pdf manuals for a Coleman Furnace Model
Have you asked Coleman.Justanswer.com?
Posted on Oct 07, 2009
Coleman dgaa furnace lights then goes out
If your talking about taking out the flame proving rod and cleaning it with sand paper or abrasive cloth and that didnt work, you may have a bad flame proving rod and it needs replaced. If the flame sensor is good, it could be the board not keeping the call to the gas valve, the gas valve not keeping the call, or your thermostat not keeping the call. Hope this helps narrow it down.
Dec 07, 2013 | Coleman Heating & Cooling
My trailer furnace is a coleman DGAA. everything seems to be running good except cool air is cming through vents. takes a long time to get my olace warm.
1 of 2 things, 1, check calibration to match control amperage, 2, check fan switch, but if you have ever changed the thermostat it more then likely your calibration. GARRANTEED
Dec 30, 2010 | Coleman Heating & Cooling
I HAVE A 4 HP GAS COLEMAN POWERMATE COMPRESSOR. THE COMPRESSOR KEEPS RUNNING AND WONT SHUT THE PRESSURE OFF UNTIL THE BLOWOUT VALVE BLOWS.THIS COMPRESSOR HAS A HONDA 4 HP GAS ENGINE ON IT.THE PRESSURE IS...
Coleman PowerMate CT4090410 Operator Parts Manual
This unit uses an loader valve to control pressure, it will unload compressor and idle engine back until the pressure falls below 95 psig and the speeds engine up and loads compressor until cutout pressure is reached. I've linked to manual and the unloader is
Coleman PowerMate CT4090410 Operator Parts Manual Page 18
The item number is 9 and part number is 070-0056.. This part is around $100-$110. Ive repaired this type part on air compressors used on mechanics service trucks ., Depending on your skill level and access to tools and parts, it might be better to purchase a new one.g take time ti read to read and understand manual. Good luck
Nov 10, 2017 | Coleman Air Tools & Compressors
Need a manual for Coleman furnace
how do I hookup my Coleman Sedona refrigerator to the propane?
Jan 15, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Short cycling
There are a few reasons why your furnace is restarting after it reaches temp. and shuts off. First, if you have a mercury bulb thermostat it needs to be level and the heat anticipator needs set properly. If you have an electronic thermostat then you need to make sure the DIP switch settings inside are set properly for propane. If you have a digital thermostat there are also settings to be made for your type of heating. These settings will be explained in the thermostat installation instructions. Also, Make sure your furnace filter is clean. If this does not help then there are some other things to check which may need to be done by a technician depending on your mechanical aptitude. Hope this helps!
Dec 08, 2008 | Coleman Propane Forced Air Heater...
Coleman furnace problem
Sometimes people replace the blower motors with a higher horse power. Has this motor ever been changed? I believe the original should be a GE motor
Nov 12, 2007 | Heating & Cooling
How to install an igniter?
if the heater uses a hot surface igniter its a simple matter of unscrewing the igniter and replacing it with another unit. if it is a spark ignition, the spark wire is a heavy insulated wire that goes to the gap. check out white-rodgers for a replacement. if your furnace uses a purge mode get a purge cycle programmable igniter.
Nov 12, 2007 | Coleman Propane Forced Air Heater...
Coleman 10' X 10' Sundome Tent 9160K101 Logo
505 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
