Question about Cobra 29 LTD CB Radio
No sound coming back
I have a cobra 29LTD. It is hooked up to the lighter adapter. The power comes on people can hear me fine but I can't hear any incoming talk. I had a external speaker hooked up and unplugged it and still nothing. I use it 5-10 times a year for coyote hunting and it worked perfect, not this time. Anyhelp is appreciated, or do I just need to take it to someone who knows what there are doing.
  • tstueve Feb 02, 2009
    Yes set up correctly, all you do is plug it into a lighter. Volume up squelch down. I wil open up and check speaker connections.
  • tstueve Mar 16, 2009
    It was blown by someone who was to close with a powerful CB. Had to replace it.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
I'd buy another radio.Lot easier than fixing the audio section..Ic chips with 16 to 30 pins(agh) and it costs $50 for each part or repair and it may not solve it. A good Uniden or Cobra is only $75 at www.copperelectronics.com or at a flea market people sell old radios for $25
Posted on Mar 07, 2013
    Guru:
  • 773 Answers
First make sure the mic is in all the way. You may even need to change mic's. there may be a broken lead in the plug. It happened to a buddy of mine. If the mic is removed the audio will drop.
Other things that can cause this.
RF gain is down. you need to turn this all the way up. there is no need to ever turn it down unless you are on a fox hunt or there is a lot of DX noise and you are talking to some one fairly close to you.
there could be something wrong with the external speaker jack. have you lugged any thing in to it? it may be stuck.
and of course the speaker. Plug in an external speaker, if you have audio then its the speaker.
If you have sound on the radio coming through the speaker, most likely its the RF GAIN, if its none of those the receive may have blown in the radio. take it to a tech.
Posted on Feb 08, 2009
    Problem Solver:
  • 17 Answers
Is the radio set up correctly? Is the volume turned up / squelch turned down?
If they can hear you but tou cant hear them, try opening the radio up and checking the speaker connections.
Ill need to know the result of those questions and tests before i can help further...
M3ODQ
Posted on Feb 02, 2009
I have a Cobra 29ltd CB with no sound coming from the internal or external speakers. So I went out and bought another Cobra 29ltd thinking that the old one was shot. Hooked up the new one and the same...
are you using the antennas that are installed thru the mirrors or the ones on the side of the truck. If you are using them you should make sure that they are connected to the coax. some just get thrown together ,antenna to mount then one end of coax to ??? so take a multi meter and set it on x1.Touch bottom of the antenna and the connector that come out of the dash. If you are connected you should get a reading. If you are not ,then you will have a problem hearing anyone because you are not connected to the antenna but the coax. If the connection is good to go then I would try running a ground wire to the chassie and maybe even a ground strap.
Mar 09, 2013 | Radio Communications
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
Feb 27, 2013 | Cobra 29 LTD CB Radio
HELLO STAN FIRST HAS THE RADIO BEEN PEAKED AND TUNED? SECOND IS THE INTERIOR LIGHT IN YOUR PICK UP RIGHT BELOW YOUR ANTENNA,IF SO YOU HAVE A PROBLEM BUT EASY FIX THE WIRING GOING TO THE LIGHT ACTS LIKE AN EXTRA ANTENNA CAUSING YOUR ANTENNA TO RESONATE TO YOUR RADIO CAUSING THE A W I LIGHT TO COME ON MOVE YOU ANTENNA BACK A LITTLE FUTHER AND SHOULD BE GOODif you want to get a bettter antenna get a willson 500 mag mount far better
How do i find and replace the finals in a cobra 29ltd classic
The protection diode (a black, tub looking devise) hooked to the positive power wire near the back of the radio, is most likely your problem. Check to see if any doides are shorted by using a Volt/Ohm Meter by checking for a short. For more imformation or help, email me at wyoed1@aol.com.
"Original Radio Man"
Ed
Jan 01, 2013 | Cobra 29 LTD CB Radio
Plugged in my 29ltd classic no power nothing lites up cord and fuze ok
You blew a diode near back of radio.(1) Take back cover off.spkr side) (2), see if you spot a black diode with a white stripe in right hand side between audio transformer and chassis near power wires coming in. (3)replace that diode; solder it..it may work again.
May 24, 2011 | Cobra Radio Communications
I just bought a cobra 29 ltd, i hooked it up and calibrated it the way the manual said but when i turn it on and turn my squelch all the way to the left i barley hear it at all, and i have the volume all...
there may be a very low noise level. If the noise level is low you will hear almost nothing. You need to go on ch 19 and drive near a major interstate.
Key up and say, "Break one nine for a radio check" and a trucker will come back and tell you its working. If you hear him okay, then your radio is working fine.
Some days, background noise is heavier and lighter then others.
Oct 18, 2010 | Cobra 29 LTD CB Radio
Have cobra 29 nw ltd keeps blowing fuses inline and in cigarette lighter adapter adapter is 10 amps and inline is no more than 5 amps
This is an easy fix if you are comfortable soldering.
You must have hooked it up backwards. Big problem when using a cigarette lighter adapter. You have to be careful, if you hook a radio up backwards you blow the polarity protection diode.
  • Go to radio shack and buy an N1004 diode.
  • Open the radio
  • Look towards the back right of the radio for a black diode D23. it will probably look burnt, but not always.
  • Use a soldering wick to remove the solder holding the diode in.
  • Remove it, and replace the diode making sure its going in the same direction as the old on. Strip on the side the triangle is pointing.
  • Solder it in.
  • Test the radio
That should do it.
Make sure you are careful to hook the radio up to power corrctly.
Nov 14, 2009 | Cobra 29 LTD CB Radio
Help with cb radio
Hello there
here is a link for the scematic ok?
best regards michael
  1. Cobra 29LTD ST, 29WX ST 29LTD ST Owners Manual. 29WX ST Owners Manual. DIAGRAMS. 29LTD ST Schematic Diagram ... WX Schematic Diagram. 29LTD, 29LTD ST, 29WX ST Factory Service Manual ...www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/index.htm - Cached
Sep 15, 2009 | Cobra 29 LTD CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
221 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
