Question about Sony Cyber-Shot DSC-P71 Digital Camera
Eror e6100 flashing
When switching onthe camera the lens moves out but the screen stays blank the focus button is not working
Posted on Jun 01, 2010
  • 21 Answers
Error is generic hardware error. normally some part of the infrared or display has malfunctioned.
Posted on Feb 10, 2009
Why does my camera not capture any picture? Whichever mode I use, it does not capture any picture regardless of how many times I click the button.
Flash flicker is the camera trying to get enough light to focus, It occurs when you press the shutter release part of the way down.
Try the same thing outside, ensure you press the shutter real ease all the way down. If it still does not fire, switch the lens to manual focus (sliding switch on the side of the lens, move from A to M) If the camera shoot then, the camera is struggling to auto focus.
Feb 23, 2015 | Canon EOS 1100D / Rebel T3 Digital Camera
My samsung es80 does not make sharp pictures anymore
Difficult to go on only does not make sharp pictures anymore.
Seeing one picture says more than 1000 words. Still I give it a try.
When you are sure you did not change the focus settings and don't switch over to macro settings, while shooting normal, I can't help. But I do advice to look in the manual on page 41 and put the camera in Auto focus. (Not one of the macro modes) then when shooting, wait till the camera has focused, while you pressed the shutter realise button half. When the camera is in focus, the square in the middle of the screen becomes green, press the button down. (without moving the camera)
Also select a high resolution (big photo size) because small photo size is easy seen as a blurred picture.
Success
Feb 17, 2014 | Cameras
Nikon d3100 taking blank images
The problem could be the imaging sensor in the lens housing, this will require a camera technician to find the extent of repair that is needed.
Apr 10, 2012 | Nikon D3100 Digital Camera
You push the button and it will not take a picture. I put new batteries in it and it still will not take a picture.
My HTsi Plus never seems to be able to Auto Focus on a subject, so when you push the shutter button half-way, it just flashes the focus indicator (telling you it is unable to focus). Try switching over to the "Manual Focus" mode. On the front of the camera there is a button labeled "AF/M". Push that button to switch to manual focus. If the camera is in manual focus, the external LCD screen will say "M.Focus". Now try to snap a shot. If that still does not work, there may be something wrong with the camera or the lens. So, try using a different lens in manual focus mode. If it still does not work, then I would say the problem is with the camera itself.
Nov 15, 2010 | Minolta Maxxum HTsi Plus 35mm SLR Camera
E6100 flashing on lcd screen
The E61 is an internal error code shown when the motor is not moving. I will look up the specific details when I get to the shop and update this with the required fix.
Dan
Oct 15, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Sony digital camera dsc s40
code error 61 related to internal lens problum.i think lens movement moter stuckup this is reparable
Jan 13, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
CAMERA WILL NOT TURN ON
I had exactly the same problem I seem to have solved it by holding down the shutter button and then pressing the on/off button. It powered up and the lens stayed out. It was not auto focusing, so I placed it into manual focus and ran it back and forth in manual focus mode. (The circular button on the back adjusts manual focus by pressing it to the right or left) I suspect it's part of the start up self test that checks to see if the auto focus system is working, if it fails it shuts off. I think I stumbled onto a override of sorts by the button combination. Running the manual focus seemed to help. I do have a small black area in the upper right of the screen that gets no light - a dark spot. I store the camera in my pocket, I wonder if some pocket fuzz got into the camera somehow...
Oct 24, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Minolta Maxxum 7000i
Is there a micro focus switch on the lens
On my lens if switch to Micro Mode the Auto focus is disabled, Also it is a stupid question but you are using a AF lens and not a xi series or manual focus lens.
Sep 28, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Can't take pictures
The focus element within your lens may not be moving normally. This can be due to contamination such as sand, impact, or failure of the motor itself. If the lens cannot resolve proper focus the auto focus system on the chip will not continue to take the picture. Another possible reason is that the button has simply failed. David Millier Advance Camera Repair
Feb 07, 2007 | Canon PowerShot A40 Digital Camera
Sony Cyber-Shot DSC-P71 Digital Camera Logo
141 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
