Question about GE Spectra JBP78 Electric Kitchen Range
GE Spectra model JBP78COB1CC
While we were cleaning our oven the inner glass broke and cracked from top to bottom. So I have two questions:
1. Can I still use the oven?
2. Can I replace the glass myself? It looks fairly simple, 4 screws, probably some type of heat glue and the glass.
3. What else should I be concerned about?
4. I'd really like to do this myself.
v/r
Jim
  • 10,865 Answers
Ok Jim - to answer your first question, you can still use the oven but it will be less efficient and will probably not operate at the temperature you set it at.
Yes you can replace the glass yourself. ?You will need the right glass for your model of stove and the installation kit to go with it.
You can purchase these at a website such as www.repairclinic.com
Posted on Feb 18, 2009
Testimonial: "Thank you very much. Now my next step is to actually order the glass and perform the repair...I may be coming back soon! :-)"
The inside glass panel, in the oven, has a hairline crack. Is the oven still usable?
Hello ewaters56 - Honestly, I suggest contacting a professional to have the inner glass panel replaced and I do not recommend for the oven to be used.
Dec 12, 2012 | Frigidaire Gallery 30" Self-Cleaning...
I need to replace the seal AND the inner door glass on my Jenn-Air sve47600 range. Haven't found anything online that helps with the glass replacement. Another question: above the oven door (and...
Hello & Welcome to FixYa
The heating issue can be caused by the oven temp sensor that is bad and needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement. You can view this video for glass replacement:
Please get back to me if you have any other questions.
Kevin
May 28, 2011 | Kitchen Ranges
Glass top on range is broken.
pull bottom panel out look on stove middle just below oven door
thumbs up
Aug 17, 2009 | GE Spectra JBP78 Electric Kitchen Range
Our handle broke off our GE Profile Spacemaker Oven
You can easily perform this repair on your own and save the cost of labor charges and a service fee. Go to appliancepartspros.com and type in the model number you provided. The door handle is located under Section 1 as item number 1801. Make sure you order the correct color.
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
May 12, 2009 | GE JVM1490 Convection/Microwave Oven
Cracked glass top
Your crack was most likely cause by a flaw in the glass top. Most GE smooth-top ranges (espesially if manufactured prior to 1/1/06) have a five year warranty covering this type of failure. The labor is not covered after the first year. Check the back pages of your use and care book for warranty info on your model. I'd advise against continued use of the cook top with a crack, as spills can get to components and cause further damage.
Aug 21, 2008 | GE Spectra JBP78 Electric Kitchen Range
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
565 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
