Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Tractor stalls when engaging the clutch/brake
Craftsman 917.256550
I have ad the tractor since new 17 yrs, always serviced it myself. Resently had a broken snapring in the Hydrostatic tranmission. After re-assembly I can hold the belt in manually (not recommened) but when I release the clutch/brake the engine stalls. how do you setup the brake on the trasmission? May be mine is warn out? or is there a way to release this?
Thanks, Ron
  • 24 Answers
There is a safety switch on the clutch pedal, that's not the problem
look at the seat safety switch .
Posted on Feb 03, 2009
Blades wont engage have 12 volts to the clutch when switch is pulled.
The clutch is electro magnetic, once 12 volts is sent throught the windings the clutch engages, so if it does not engage there is more than likley a brake in the internal windings which unfortunatley will mean a new clutch.
Aug 29, 2012 | Craftsman GT 5000 26 HP54" Garden Tractor...
Craftsman Model 917.259566 Tractor starts perfectly, but stalls out when the clutch is released. Whats happening?
Most likely your seat safety switch is not working. In order for the engine to run with blade engaged, the operator present switch must be made when the brake is taken off (releasing clutch).
Oct 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Stalls when put in gear or engage mower
your lacking power and probably need to clean your carb or adjust the main idle screw..its on the botton of the float bowl...back it out a half turn...start with a quater..well its running
Jul 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Sears 26 hp garden tractor that stalls when I let off of the clutch/brake or engage the mower blades. I have bypassed the under seat swith, and I have also bypassed the clutch/brake switch. The...
does it run off of a pto system or is it a lver type if its a lever type there is a switch under the lever also you might have something caught in the deck causeing it not to engage blades if i can further help e-mail me wade at wadembly@aol.com
Jun 24, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Tractor stalls when letting out clutch
Sounds like the clutch safety switch is going bad.
May 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor stalling
check wires on switch under seat
Oct 11, 2008 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
476 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
