Re: Work centre 24
there is a 1/8'' streak aprox 3.75 inches apart on the whole print. The
yellow drum was replaced after a yellow streak appeared in all prints.
After the drum was replaced it appears that the printer is printing all
colors in these streak except yellow.
Second problem: After several prints a slight cyan streak appears and
gets worse with each print. These cyan streaks and at a 90 degree angle
to the 1/8'' streaks in the first problem. The cyan streaks are aprox
1/2'' wide.
Please help if you can. I don't want to tear into this thing without knowing a little about what I'm looking for.
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
How do I scan an undersized none standard document [9.5 x 7] 2 sided page to pdf for ultimate copy...
(More)
How do I scan an undersized none standard document [9.5 x 7] 2 sided page to pdf for ultimate copy into word for editing? Feeder will not work for this process,, When I press the start buttom, nothing happens.
we replaced the transfer belt for CQ issues. we need to adjust skewing problem and computer to...
(More)
we replaced the transfer belt for CQ issues. we need to adjust skewing problem and computer to equipment problem -- software acts up when interfaced with legacy management diagnostic tool wont allow tech to get into diagnostics.
Call for Service warning. What could this mean? Machine will not operate. I've change the toner...
(More)
Call for Service warning. What could this mean? Machine will not operate. I've change the toner cartridge turned it off and back on. Still get Call For Service message.
