Need door catch wiring diagram for hotpoint wf240 washing machine
Changed bearing but door catch wires were still in, two pulled out, one stayed in. got two red with green on, and one black. they're marked 123, number 3 stayed in which is the red/green.
any ideas where the other wires go?
  • 2 more comments
  • mandapanda19 Feb 03, 2009
    need to know if black wire goes in number 1 or number2 as number3 is red/green.
    just dont want to put the wires in the wrong side and blow washer up
    not sure whether number2 is also red/green or black as got one of each colour wires that pulled out
    no tech sheet on machine and there is no light to indicate when door opened
    Sergeant:
  • 326 Answers
Http://www.freepatentsonline.com/3899204.html
click this link for instructions and  click this link for diagrams http://www.partwizard.net/enlarge/9072/
Posted on Feb 03, 2009
  • 15,935 Answers
Black Ground Wire is in center position.
Thank you for using Fix-Ya - a FixYa rating is appreciated!!
  • blueextc3221
    blueextc3221 Feb 03, 2009
    Please see this picture - as it is 2 model years before yours, but still the same switch. Black ground wire is in the center.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Have you checked for a tech sheet that includes a wiring diagram? Almost always, such a tech sheet would be available right inside the machine; attached to a cover/panel, at the bottom/kick panel or behind the controller board.
If I may ask, does your unit have a light that lit up when the door is opened? Pls post back.
Good luck and thank you for using FixYa.
    Sergeant:
  • 250 Answers
Http://www.flickr.com/photos/zenzoidman/164419360/
click the link and get the picture of wiries connected in the door assembly.
  • Washing Mach... Master
  • 19,396 Answers
Normally, hotpoints have two white wires and a yellow, or brown yellow wire. Like on this diagram here.
Normally the wiring diagram for your dryer is held in console area or under the dryer top panel
You can test voltage using a multimeter if you do not have the wiring diagrams.
  • 679 Answers
number 3 is for green and other are for 1 and 2
  • rockfixya
    rockfixya Feb 03, 2009
    please follow the link >>
    http://www.mendmy.com/answers.php?id=194...
  • 13,433 Answers
Hi
These documents should have the info you are looking for
http://cgi.ebay.co.uk/Domestic-Appliance-manuals%2FEngieer-service-info-manuals_W0QQitemZ120361258000QQcmdZViewItemQQimsxZ20090110?IMSfp=TL090110111001r35133
Open above Ebay sale link.
  • Ekse Feb 03, 2009
    The documents in my link include
    Wiring connection charts for single & 3 Phase models
    Genius:
  • 1,913 Answers
Put 1 number in left and 2 n right.
Wiring diagram for Hotpoint 31331r door catch
only 3 wires on most dryers one is for light other to shut dryer off when opening if plugged in wrong. dryer will run with door open
light will stay on when door closed reverse them if that happens
some only have 2 wires don't matter on them
need whole model# for more info
Jan 08, 2015 | Hotpoint Dryers
How do i fix a noisy spin cycle on hotpoint wf250
Hi.
A noisy spin cycle is usually because the bearings are rumbling and/or collapsed.
Unfortunately this is not a simple job and would require a service call and probably a workshop.
Good luck.
Nomess
Sep 28, 2014 | Hotpoint Repair Pcb / Module Wf240 Wf250...
Hotpoint wf240 has stopped working, sounds like the motor or brushes. Problem is there is washing in the tub and we cannot get the door open.Please advise how to open the door ?
Return the program dial to a finished position. Power the machine off (Unplug it). Leave it 20 minutes and it SHOULD reset. Note, if there is water above the level of the door, it is a good idea to pull the machine out and tip it back slightly until the water is not against the door, then you can remove clothes and bail the tub out
Jun 21, 2011 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint ultima wt761 door catch has broken how can i open the door
If you have a broken door catch you can get the door open by feeding some garden wire around the right hand outside of the door (between the door and the metal casing of the washing machine).
Once you've fed it in round the top right and bottom right curved corners pull the two ends of the wire to the left, so that the wire pulls against the lock mechanism, and the catch should release.
Feb 26, 2011 | Washing Machines
Hot point WF451 Issue. I want change the door rubber between the door and drum. How do I do this? Also the machine is making a noise on fast spin as if there is something in the drum catching. I have...
Hi for changing the door seal check out the video section on www.selfix-uk.co.uk there are a few videos on the wf including bearing change which also covers the door seal as well. As far as the noise in your machine it could be almost any thing...if it's a scrapping noise it may be a bra wire caught between the drum and container, if its a tapping noise it may just be loose wires hitting on the cabinet or you may have a coin between the drum and container if it's a loud rattle, you could also have something in the pump housing...it's hard to diagnose noises without actually hearing them sorry
Jan 23, 2011 | Hotpoint Aquarius WF000 Front Load Washer
I've repaired the bearings in my wf000 hotpoint washing machine, put it back together now it won't pump the water in, and the door lock light does'nt come on! any idea's wot is wrong?
I would say you have missed a wiring connection somewhere or connected the module up wrong. Hopefully you noted where all the terminals came from when you dismantled it or you may need a wiring diagram.
Mar 16, 2010 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT WF00
Deasr dashdach
Peace,
From ngafm,
I understand that you have,
HAVE REPLACED DRUM BEARINGS, MACHINE RUNS,BUT WILL NOT COMPLETE WASH CYCLE ( FILLS, WASHES BUT WILL NOT MOVE ONTO SPIN ) TRYING TO GET WIRING DIAGRAM TO CHECK I HAVE RECONNECTED THINGS IN RIGHT PLACE !
How old is this washer that you are spending so much money in parts for?How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Sounds like you really need a Hotpoint trained tech , so as not to spend weeks repairing, or not your washer.
My father and grandfather used to teach me , ("When in dought, don't)
If I were there I could show you the wiring order without the diagram!!!!!!!!!!
In the USA thousands of deaths and house fires happen when corners are cut, and cost home owners much more than the few bucks they plan on saving!
Do it right, like the rest of the things you did in you life to get this far!
Call a factory service and let them help you.
Stay healthy!
You will be fine.
Bless You,
ngafm1
Please give me a good rating for this fine advice i give you, before you sign off.
Thank You
Sep 04, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Jun 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
