Question about Miele Novotronic T230C Electric Dryer
No heat cant find the thermostat
Does anyone know where to find the thermostat inside this machine ive taken the sides off but still cant see it..help
  • amighini Apr 04, 2009
    doesnt work the heater!!!!!!
  • 56 Answers
It sounds like it is the heating element which will be behind the back drum in front of the intake blower motor it may be disconnect or worn out make sure the it is unplugged before taking the machine appart very high voltage!
Posted on Feb 02, 2009
How to replace/repair the water pump?
  • Pressure test the cooling system for leaks.
  • Remove and replace the water pump if bad.
  • Fill with new coolant.
  • Install new radiator cap.
  • Install new thermostat.
  • Test drive car.
Mar 24, 2016 | MotoBatt All years honda fes125 125 cc...
Hi i have a 2001 2.0 turbo diesel hyundai sante fe... The heaters arent working properly they are blowing cold air only... Ive checked the oil to see for signs of water or coolant and water for oil vice...
Is there anyway to remove the section of hose that is blocked and replace it heater hose? I'm thinking if you can replace the section that is blocked them it should allow coolant to pass through all hoses therefore giving you the heat your after!! I've also had goodluck searching u tube for answers and in most cases comes with a detailed video goodluck in your mission for heat!!
Nov 09, 2014 | 2001 Hyundai Santa Fe
I have a bush AE56DW oven bottom oven was working, but now only the fan works and there is no lights or heat coming out?
have the very same problem on my bush stove though have just found the problem out, on the oven switch looking inside has all the wires but what hidden and needs taking out it s fuse near the knob and cannot be seen until taken out and your see this thermal fuse blown this stops all power to inside stove light no power then to thermostat oven temp everythings dead,
ive tested everything untill ive looked at replacment parts and then your shown a fuse of 240 vol when do they put this in such a place clear to have use all have to call out an engineer, ive beaten the system
Apr 05, 2014 | Ovens
Heat cuts out shortly after dryer starts. Have taken apart several times. First replaced thermal cut off (tested bad) and thermostat. Element ok. Good airflow. Dryer seems to heat up very quickly and very...
Sure can!
Most Kenmore style dryers have a heating element that has a long wire coil inside it, (often there are two wires or elements inside one housing). Regardless, if you have carefully checked the air exhaust, and you find it is "perfect" ( means no back-up heat from a plugged or impeded air flow) and you have determined the air flow inside the machine is like new, ( no back up there either), then what has possible happened is the wire heating element has wiggled loose and is touching itself, thereby shorting out and making super heat.
The wire coils are usually held loosely in place with white ceramic rings, to keep them from touching the metal housing. If you carefully remove the heating element "box or "tube" and look inside , you may be able to see the problem. Testing it with an ohm meter will not work, it will simply test OK. The element is made to heat at a certain temperature according to it's length, if it touches itself, the elecrttricity will take the shortest route and may make your element glow white hot in one spot. Be blessed.
Sep 02, 2013 | Kenmore Series 70 80 90 PN281798 Dryer...
Hello all, The boiler of my Trevi Spidem does not heat up anymore. It happened after the machine was descaled with vinegar. Stupid to use vinegar, but it happened. I rinsed the machine very well, but the...
Hi
If the machine turns on and cycles normaly your heating element is probably gone, but if your machine is less than 4 years old you may have a thermostat that can be reset. They are located on the side of the boiler (round boiler and hard to get to) and there is a reset button between the wires going to the thermostats (2). Push the button and listen for a faint click. That may help, but not guarenteed.
Oct 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
Stalling problems
Remove the raidator cap while running or watch the overflow tank for bubbles. If you see bubbles either way, most likely your cause of the overheating is a leaking head gasket. If you have a cooling system pressure tester, pump up the cooling system and see if it looses pressure, if it doesn't hold pressure, again bad head gasket.
Jun 23, 2008 | 1989 Ford Crown Victoria
Open Questions:
See all Miele Novotronic T230C Electric Dryer Questions
Miele Novotronic T230C Electric Dryer Logo
480 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
