Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
Cozy heater 35000 btu pilot light goes out every 4 days
I have a brand new cozy heater with standing pilot. The pilot light goes out about once a week even with vent switch bypassed. It usually goes of when heater is on low position. Gas pressure was checked by a tech its withing normal limits. An;yone know what other tests i can do to pin point problem? If the pilot flame is to high could that cause it to do that? thanks.Frank
    Problem Solver:
  • 10 Answers
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Posted on Feb 03, 2009
    New Friend:
  • 49 Answers
If you can re-light unit all parts are good, if vented into a chimney or too many elbows will cause this.
Posted on Apr 06, 2015
I have a cozy model cdv255 direct vent wall furnace and the pilot light keeps going out. What causes this
dirty fuel line.have see where spider web is enough blockage to cause this. but aslo have found that the thermocouple needed replaced.
Jan 08, 2015 | Cozy Heating & Cooling
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
My cozy floor furnace wont come on
NEED MORE INFORMATION. IS THERE A LED LIGHT THAT FLASHES A CODE?. IS THE THERMOSTAT OPERATING PROPERLY? IS THIS UNITS FLUE EXHAUST VENTED TO THE OUTSIDE? & IS IT FREE OF OBSTRUCTIONS?,
Dec 25, 2012 | Cozy Heating & Cooling
I have a 50,000 BTU doublesided Cozy wall furnace at my cabin. Recently the pilot keeps going out, I suspect it is caused by a chimney downdraft when I close it up for the week. Can I put a wind...
make sure you have 3 feet of vent pipe out of the roof and you have a UL listed vent cap, if you can re-light the unit all parts are good.
Nov 23, 2010 | Cozy (W352E) Heater
I have a W355F Cozy wall heater. I lit the pilot and turned the value to On. Previously the heater would turn on when the temperature set on the thermostat was appropriate. However, after a few days the...
I would take out the new stat and return it.Just because it was new doesn't mean it didn't have a factory defect. I see this all of the time buying a/c and Heater parts that I have to return for credit.
Good Luck, Shastalaker7
PS It sounds to me like you know whats up.Sincerely, Shastalaker7
Nov 06, 2009 | Cozy (W352E) Heater
New Cozy Enclosed Front Console 70,000. Pilote goes out, gas stay
its not the valve you have a problem with the heat exchanger a baffle issue have to change.
Feb 13, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
When unit goes on, there is a slight odor of gas when the valve
Cozy cheapened their heaters awhile back doing away with the air shutter. Without the shutter, a little gas can seep out into the room before it ignites and cause an odor. As for the curing odor, can you see the pilot flame looking down from the top of the heater? The pilot should be well inside the exchanger out of view. If you can see it, fumes from the pilot are getting into the room causing an odor. I had to remove the plate that holds the pilot assembly and drill a new hole shifting the plate over where it belongs. It was poorly assembled at the factory. Hope this helps.
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
584 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
