Where can I find Durabrand Cd-1493 service manual?
I bought a campact disc player (Durabrand; Model CD-896; made by Lenoxx Electronics Corp) which did not include AC adaptor. Now I am trying to find a matching adapter (DC: 4.5V 500mA). Can I find it on...
Power supplies with those specs are common online. Radio Shack could probably set you up with a universal power supply that adapts to all the common plug sizes.
web search "4.5V 500mA dc supply"
Sep 09, 2011 | Audio Players & Recorders
I have a Durabrand CD player (model CD-1095) and I can't find the cord to plug it in, so I wanted to buy another cord without having to buy a whole other CD player. Is that possible?
A standard web search found the obvious answer.
"Durabrand CD-1095 power cord"
http://wiki.answers.com/Q/How_do_you_get_a_cord_for_a_Durabrand_CD_player_model_cd_1095
"You can purchase a generic power cord at Radio Shack. I had the same exact model and found that their catalog number 61-2875 was a perfect fit. It lists for $7.99. To be sure, take your radio in for an exact match. Good luck! :o)"
Aug 03, 2011 | Audio Players & Recorders
How to set the source button on my durabrand surround sound system? My sound on my TV is out so we were running it through the dvd and cable and it worked fine, but now when we turned it back on ( after...
Now the story comes into focus (somewhat). The remote probably had a button or two pushed while it was 'lost' and a setting in the Durabrand (model???) is unintentionally changed. FIND THE MANUAL and examine every indicator to see what was changed.
Jun 30, 2011 | Audio Players & Recorders
Looking for manual for ht-3915 durabrand home theater system
Dear bluemntman16
You can download the manual from this link
http://www.scribd.com/doc/46043752/Durabrand-HT395-Home-Theater-User-Manual
Thanks for using FIXYA
Mar 15, 2011 | Audio Players & Recorders
Need to find a replacement ac cord for a Durabrand AM/FM cd player. ( boombox )
if there is a little bit of slack left on the boom box you could just find any ac cord an spice it, or if there isnt any at all just find somthing you dont use an hook it up in side
Oct 15, 2008 | Audio Players & Recorders
Volume Issue with CD Player by Durabrand.
it just seems a setting problem.
go to AUDIO SETTINGS or MENU.it will have "ON VOLUME".
press volume control -ve to get desired volume.
press AUDIO or MENU to store volume level.Next time u turn it ON ,the volume will be what u SET. OK i hope this solves your problem.
Mar 24, 2008 | Audio Players & Recorders
How do I set my clock on my Durabrand car stereo/cd player?????
I'm not sure of the model # of your product but just mess around to get the hang of it. i never read manuals unless they're extremely important!
if u really need help find ur model # go on the web to google and type in the model #, product manufacturer, and "manual" after that.
that hopefully should help
Mar 21, 2008 | Audio Players & Recorders
Durabrand 2.0 CH USB Speaker System
Hi, Based on your post/description, the Durabrand 2.0 CH USB Speaker System is a basic external speaker that plugs into your PC's speaker/headset output (green jack). It is supposed to get its power from the +5VDC supplied by the USB port. Some USB port have current limiting therefore it can be anywhere from 10 - 500 mA. The power requirement of your external Durabrand speaker maybe beyond what the PC's USB ports can supply. It does not need to be recognized by the OS since it only connects to the USB to get power but there is no data interaction. Perhaps what you can do is get an external +5VDC power supply whose output is in USB type connector. The current rating would depend on the requirement of your speaker. Offhand, if the speakers are not that big, probably a 1 Amp would do. This is of course assuming that the Durabrand speaker system is fully functional. If with an external power supply it is still a no go and you have verified that sound do come out of your green jack (with the use of an ordinary headset), then the Durabrand is defective. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 22, 2007 | Denon AVR-987 Receiver
43 people viewed this question
 Grubhead
Grubhead
