Program in C to check whether a given number is a Zuckerman numbe
Eg; 384
3*8*4=96
384/96=4
  • M Norwood May 11, 2010
    A program in C to check whether a given number is a Zuckerman number.
    It would help, of course if you told us what a Zuckerman Number was. (A number that divides by the multiplication of its digits leaving four, perhaps?)
  • clarify what exactly you need?
    President:
  • 392 Answers
Check this website, you'll get all your answers there:
http://www.codeproject.com/
Posted on Feb 09, 2009
Value of starr baby grand piano serial numbed 207229
Value of starr baby grand piano serial numbed 207229 Google Search ..i can not find your model number but try this link it might give you some idea what its worth.
Dec 02, 2016 | Grand Music
I have 4 lines that were made into speed dial numbers then deleted. On this phone (although not other phones on the same network) they now appear as "blank". If calls are put on hold from another phone to...
You call your Nortel service tech, unless you know the installer password and are familiar with programming. You have to go back into set programming and reassign the lines.
May 20, 2010 | Nortel T7316E 2-Line Corded Phone
How to knw that a given memory contains a garbage value or some allocated value thru a program(garbage collector)
just check it against a condition which checks whether the variable is already assigned a value. if not it probably has a garbage.
Oct 20, 2009 | Borland Turbo C++ Suite 1.0...
How do you tell with an imei number if the phone is a original or fake
To check whether your phone has an IMEI number:
1. Dial *#06# – A 15-digit number will be displayed on your handset.
2. To validate the IMEI, sms IMEI <15 digit IMEI number> to 53232 (Rs. 3 per SMS) For eg; IMEI 351869910223340 to 53232
  • Message displayed for correct IMEI – Success!!
  • Message displayed for incorrect IMEI – Alert!!! Invalid IMEI (tough luck).hope you have valid imei number.rate me if i have helped you
Sep 10, 2009 | Nokia 8800 Cellular Phone
Authorization code.
my serial number :1045-1090-6246-8353-3166-2968
my activation number :5103-2249-9503-2245-5674-9094-4063
activation type : Normal: 194:13
my authorization code ? please answer!
Apr 29, 2009 | Adobe Computers & Internet
Casio TE4500F Programming Departments & linking to PLU's
Hi.
To link a PLU to a dept:
Turn key to program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number and press the 'PLU' button (eg 1 PLU for the first plu)
Now type the dept number to link to. Use two digits eg 01
Now press 00 (double zero)
CASH
SUBTOTAL
To set a dept name:
Turn key to program.
2 SUBTOTAL
Type dept no in 2 digits eg 01
Type 05
SUBTOTAL
Type new dept name using character sheet
00 (double zero)
CASH
SUBTOTAL
That should do it.
Let me know if you have problems.
Mark
Dec 18, 2008 | Casio Parts Cash Register PC Desktop
Need help in Special Formatting Number
Here is one solution. You might consider adding more robust error handling.
if the decimal numbers passed to the div function are multiples i will be a non-zero number of that multiple otherwise i will be zero.
Dim i As Integer
i = div(12, 0)
If i = 0 Then
'not multiple
' do this
Else
' is multiple
' do something else
End If
Function div(ByVal numerator As Object, ByVal denominator As Object) As Integer
dim n , d decimal
Dim result As Decimal
Dim remainder As Decimal
If IsNumber(numerator) Is True _
And IsNumber(denominator) Is True Then
If numerator <> 0 Then
n = numerator
d = denominator
Else
GoTo error1
End If
Else
GoTo error1
End If
result = Decimal.divide(n, d)
remainder = Decimal.remainder(n, d)
If remainder = 0 Then
div = result
Else
div = 0
End If
Exit Function
error1:
msgbox("Numbers must be non-zero numerics", , "Multiple check error")
div = 0
End Function
End Function
Aug 06, 2008 | Computers & Internet
Video Card
download (PCwizard) install it and run it checks your computer for all drivers needed and lists them
Note name and number of drivers required and do a search on net for them
EG cmedia 2341 drivers substitute your driver name and numb
Jul 02, 2008 | ASUS Computers & Internet
I can not get the radio station that I want programmed into the stereo. I do not have the manual for it. It has DRB5475 on the front panel.
u can go to caraudio.manualsonline.com and tofixur problems onece u got the raadio staion in that u what hold down the numbe pad like hold down the number 1 butttonitwill beep then let go
Apr 08, 2008 | Car Audio & Video
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
