I was trying to adjust the monitor settings on my Westinghouse LCM 17x7 monitor. When I hit apply, the screen went black with an "Out of Range" error message. I can not get back to my desktop to try to correct the problem.
  • 65 Answers
Reboot and hit F8 continuously after the beep. Choose Safe Mode. Open the
configuration window again. Move the bar and then move it back to whatever
Safe Mode had it set at. Hit apply. Reboot.
Posted on Feb 02, 2009
I have a Westinghouse monitor Model # LCM-19v SL the monitor keep turning off. Unplugging then replugging gets it working then it shorts out again. Can I replace the power Supply cord - Potrans ITE Power...
i also have a 19" westinghouse monitor the screen on mine goes black i just turn the monitor of then back on the problem is it's overheating and from what i understand it's caused by faulty or worn capacitors the ones that are bad are vented on top so it's easy to tell the bad ones. you can see what they look like on line!
Nov 18, 2010 | Westinghouse LCM-19v1 Monitor
What and how much is a power supply board for the westington lcm-22w2 monitor. my tv went out i took it apart checked the circutry to me doesnt look like anythings rong. dont know what the caps are the...
Check here: <a href=""></a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a href=""></a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href=""></a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a href=""></a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 26, 2010 | Westinghouse Electric LCM-22W2 Monitor
Screen goes black after fraction of a second
More likely to be bad capacitors in the power supply, see LCM-20V5 (almost the same chassis as used in LCM-19V5) example:
Post back what you see insdie so we can guide you further.
Mar 15, 2010 | Westinghouse LCM-19v5 Monitor
I have a Westinghouse LCM-19v5 monitor. When I start the computer, after the startup screens, the monitor goes black and I get a red bar with the message "Out of Range." I am in safe mode right now, the...
in the safe mode you have to change the resoulution and the frequency to 60 hz you can get it by fright click on the screen and then choose properties and then choose settings and adjust the resolution to 1280 to 800 and then choose advanced then choose monitor then choose the frecuancy to 60 hz ok and apply ok and insa every thing will be ok conntact me for more if you still haveing the same problem
Nov 14, 2009 | Westinghouse LCM-19v5 Monitor
Black screen after a brief windows loggin screen
It's either the backlight, the inverter or the power supply. My shop would charge $50.00 + parts + shipping. I've repaired alot of Westinghouse monitors and I haven't junked one yet.
Jul 28, 2009 | Westinghouse L2046NV Monitor
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
Images and letters are fuzzy on my Westinghouse Monitor
Your monitor settings are not correct or you have a bad monitor cable. Wide screen settings are sometimes hard to figure when you have a wide screen Westinghouse mntr. You have tried all common resolutions? 1024 x 768, 1280 x 800, 1280 x 720? I assume your video drivers are the latest?You have tried all common resolutions? 1024 x 768, 1280 x 800, 1280 x 720? I assume your video drivers are the latest? That monitor is a **** btw! take it back to Best Buy. No other store sells them that I know of.
Jan 15, 2009 | Computers & Internet
Westinghouse lcm 19w4 has to be used in brightest mode or
I had this same problem and going through the on-screen menus I found a reset option. I reset the monitor settings and the scrolling bars went away. I plan to leave it powered up for a while to see if they come back.
Jan 13, 2009 | Westinghouse LCM-19v1 Monitor
Can't find correct setting for westinghouse lcm22w2 monitor
I don't know if this actually will fix your problem, but all LCM 22w2's are plagued with the 'white screen of death' and eventual power shutoff, including garbage characters and faulty menu, video output, etc. Here's how I fixed it.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supplyboard. This is a common problem plaguing motherboards and LCDflatpanels that use capacitors from Taiwan. If you know how to solder,or know somebody that can, it's actually a pretty easy fix. Take outthe yellow circuit board on the inside, write down the specificationsfor each of the capacitors (the cylindrical things) go to theelectronics supply store and get the replacement capacitors. You can goover the voltage specification (not under), but keep the capacitancevalue matching. Replace one at a time. Go to foradvice, tutorials and training on doing this. *You really shouldreplace all the capacitors*, but the very large one next to the powerplug I did leave on the board because I couldn't find a match. To mydelight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this. for professional hosting solutions
Jan 07, 2009 | Westinghouse LCM-22w2 Television
Computers & Internet Logo
407 people viewed this question
David Payne
David Payne
