Question about Proview PL913S 19" Flat Panel LCD Monitor
Colored lines on screen
Proview 3200 flat screen. Colored horizontal lines when I turn it on. What happened....HELP !!!
  • Proview Master
  • 5,568 Answers
This may be caused by the death of a display driver circuit and these might be integrated with the display itself.
The pixels on the screen are controlled by an X-Y matrix and the matrix may have signal lines that are somewhat shared for different screen positions.
I doubt that this is DIY project and the failure can only be located by an equipped and trained tech.
Posted on Feb 02, 2009
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Tv has sound but only colored vertical lines on screen
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken .
Good luck in handling the problem....
Jun 26, 2011 | Proview PA-32JK1A 32 in. LCD Television
My flat screen tv has different colored horizontal hold lines across my screen. Where is the button for horizontal hold?
Those colored lines are a bad panel. Is no button to make them go away. The only fix is to replace your panel. Would be more cost effective to replace the TV.
May 06, 2011 | Dynex DX-LCD37 TV
Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 07, 2009 | Proview PA-32JK1A 32 in. LCD Television
No picture
bad capacitors in the power board area these can be replaced and soldering is required to replace them
Nov 30, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PL913S 19" Flat Panel LCD Monitor Logo
217 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
