Question about Samsung HLN617W 61" Rear Projection HDTV
Cold temps/projection tv
I live in New Hampshire & am moving.....I'm concerned about ''storing'' my Samsung Projection TV in the truck for a few days with temps below freezing (perhaps to 0 degrees F). Will this hurt my TV?
    President:
  • Samsung Master
  • 1,779 Answers
No it won't. The tubes are filled with clear ethylene glycol ( anti-freeze)
Posted on Mar 10, 2009
SOURCE:
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Timer & lamp flashes and wont start
Tv projection lamp been inside this tv like 1 1/2 or 2 years already and tv it is on daily used it like 4 or 5 hrs every day?Yes,than the tv projection lamp live are ending already and the causes.
May 26, 2011 | Samsung HL-R6168W 61" HDTV
My projection tv display got really dark a few days ago. I didn't change any setting before it happened, but I tried to change them today in order to lighten the display, but it didn't help. Could a...
Yes,most likely the projection lamp life are ending.The tv projection lamp been inside the tv like 1 1/2 or 2 years?Daily tv watches like 4 or 5 hours regularly?Yes,than the projection lamp life are ending,tv do need a requirement of a new projection lamp.
Jan 06, 2011 | Samsung HC-P4752W 47" Rear Projection...
The color wheel on my Samsung HLN-5065WX shattered. I carefully replaced it with a new one. Checked all re-connected wires twice. The TV will not turn on. It doesn't make any sound. The lamp and temp...
The tv projection Lamp in the tv now has been in it like 1 1/2 or 2 years, tv in used like 4 or 5 hours a day.When ur colors wheel was destroy and shatter?Yes,it is the tv projection lamp is life are over.
Dec 11, 2010 | Samsung HLN5065W 50" Rear Projection...
Tv was working fine but due to a house move on way to new house went over a few speed bumps and now there is no picture samsung
Take the tv back cover out check for loose connections,reconnect all connections tightly and firmly.Check the projection lamp again,might be broken or damage on the move.
Nov 27, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Aug 02, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung dlp hln617w does not tun on
this model number do not use lamp ?????????
Jun 09, 2010 | Samsung HCL4715W 47" Rear Projection...
We have a 55inch sony rear projection TV and it is stored for the winter but its down to 10 below zero will this harm the tv if we leave it for the winter we live in alaska
Your TV is not a rear projection it is a DLP if had been a rear projection the answer would have been YES! Cold would damage all 3 of Tubes But you have a signal Lamp so TV should be OK.
Dec 08, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung hlr5067w shuts of after 30 seconds... flashes red
I would suspect the lamp first as they can cause intermittent shut down issues.
Nov 03, 2009 | Samsung HLR5064W DLP Projection TV
Samsung HLN617W 61" Rear Projection HDTV Logo
230 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
