Question about Janome 6019QC Mechanical Sewing Machine
How to replace bobbin case
Cannot replace bobbin case, how does it "sit".
  • 66 Answers
First take off the needle plate and then tur n the handwheel toward you until the hook on the race is at the 1 o'clock postion then slide the bobbin case in you may have to work the handwheel back and forth to get it to slide in
Posted on Feb 03, 2009
The mechanism where the bobbin sits moves when sewing so it jams the thread underneath in the bobbin area
the bobbin sits in what's called the bobbin case,, the bobbin case needs to be checked to see if there is something wrong with it and if it needs to be replaced or if the hook and hook race may need to be adjusted.
Jun 07, 2015 | Sewing Machines
How to replace bobbin assembly correctly on my singer merritt 4530 ? the threads been getting caught all around the bobbin assembly.
Yes, it should, and you might want to download your user's manual free at the Singer website, because replacing the bobbin case is pictured there.on page 41, along with instructions.
However, I can tell you that the feed dog plate with the two screws in is DESIGNED to be removed, and must be removed to get the bobbin case back in. It's important that you follow the instructions; the case must be inserted correctly so that it does NOT move, and make sure that it sits evenly in the bobbin basket (the thing that holds the bobbin case. While you are at it, you might want to also clean the basket, using q-tips with a drop of ONLY sewing machine oil on the cotton, making sure you also get under the lip before you put the bobbin case back in.
Jun 11, 2014 | Singer Sewing Machines
Bobbin case inserting wrong
hi, Can i ask what model Pfaff it is ?
Regards
Rob
www.electronicrepairs.co
Dec 29, 2013 | PfaFF Sewing Machines
I suspect the "housing" you refer to is not seated completely. Be sure to wiggle it until it slips into place. Once it is seated, the bobbin case should seat firmly as well.
May 02, 2017 | PfaFF Sewing Machines
Metal Bobbin Case falls down in machine when I try to sew
the bobbin case needs to be checked to see if it needs to be replaced
and also checked the hook and hook race.
Feb 16, 2013 | Sewing Machines
I have a Necchi 4900 and the thread catches on the bobbin holder , moves the bobbin holder out of place , james , have taken it out cleaned everthing under the bobbin and takewn the underneath cover
try changing the needle to see if that helps
if it doesn't,, then I suggest that the sewing machine be checked
at a repair shop to see if the bobbin case needs to be replaced and
to see if the hook and the hook race need to be replaced
Nov 01, 2012 | Necchi Sewing Machines
How to adjust bobbin tension on 158 model
You have two ways to adjust, 1. On the machine there is a adjustment knob..usually numbered between 1-9, set knob at 4 2. There is the bobbin case, usually metal which holds the bobbin, the bobbin sits inside this unit and there is a flat plate which the thread slides under when sitting the bobbin in case, there is a tiny screw which shouldnt be too tight but if you hold string while bobbin is in case and slightly yank the string while everything is dangling, it should only move a inch or so..ok
Jul 09, 2011 | Kenmore Sewing Machines
How do I replace the bobbin case in singer machine 7442. The manual diagram is minimal and I replace it incorrectly and just got it out after several attempts. Can't seem to get it aligned proper;u
When you insert the bobbin case, make sure the "knub" on the bobbin case (#1) is just to the left of the position finger bracket (#2). It should sit in there nicely and you should be able to spin the hand wheel freely.
Let me know if you need more help,
Chris
Jun 07, 2010 | Singer 7442 Mechanical Sewing Machine
What is a rook race
The hook and race is part of the area that the bobbin sits in, the bobbin sits in the bobbin case, the bobbin case sits in the raceway commonly known as the hook
Oct 29, 2009 | Singer CE-100 Futura Computerized Sewing...
Brother SE-270D balance wheel is very hard to turn manually
This is the first and foremost problems that I've found: The bobbin case is packed full of threads. The needle is crooked and must be replaced.
1. The bobbin case has a hook that turns to catch the top thread when the needle is down. The bobbin case assembly must be removed and cleaned totally. The bobbin case assembly is where the bobbin sits. The bobbin case has a black bar that sits on top of it. Listen the forward screw and slide the bar slightly. You will need to move the hand wheel to move the hook to the front-most position. When you have done this the bobbin case will come out easily. Clean it thoroughly and put one drop of oil on the track. This is a lower spot where the bobbin case sits on top of. Before you put the bobbin back in you need to check the tension. It is intended to be even with the top tension.
2. Replace needle and make sure it is in totally and is seated the right direction.
HOPE THIS HELPS
Apr 14, 2017 | Brother SE-270D Computerized Sewing...
Janome 6019QC Mechanical Sewing Machine Logo
1,402 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
