Question about Whirlpool Dryers
Whirlpool dryer does not heat up
When I turn on the dryer. It rotates. But the dryer drum is cold. The heater is not on.
Clean out vents
Posted on Feb 04, 2009
2 Suggested Answers
tcshack
  • 28 Answers
SOURCE: Whirlpool dryer heats but the drum doesn't rotate
There is usually a large belt that goes around the drum to turn it ...it is either fallen off the motor pulley , broke .....or the motor may be gone in it ....not sure if there are any fuses for the motor on your dryer .
If you can tip the dryer over the bottom is usually open and you can see the motor and belt from there
Posted on Jan 09, 2009
Dbsr463eg7ww no heat
First check to see that the exhaust venting line is clear (not full of lint) as well as the path in the dryer to the line. This is the most common cause of no heat.
Second set the knob to heat turn on dryer with the lights off and the door open but the "open door" switch so that it still rotates with the door open. Look at the back of the rotating drum for a orange/red glow behind the drum (the heater coils). If there is no glow the heater coils are probably broken.
As the dryers age, the amount of thermal cycles the heater elements go through until the point when the coil wire breaks. There usually two heater coils behind the rotating drum (one hotter than the other and when combined the hottest heat temperature setting. You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to get to the heater coils. Since no heat, both should be broken and will require replacement.
Nov 05, 2013 | GE DWSR463EG Electric Dryer
Dcvh660ghbb dryer wont heat
Sep 05, 2013 | GE Dryers
No high heat in dryer
This type of dryer has 2 rows of elements. If one is out then you will not have high heat.
Basically to get into ge dryers your start by popping the top then removing the front. Then the drum comes out.
Dec 05, 2012 | GE Dryers
Dryer does not heat
Might be a limit or a the heater element.MY REPAIR PAGE
Aug 15, 2012 | GE Dryers
I smell a burning smell. when i open the dryer, there is smoke
Firt make sure the lint filter is clear and the air exhaust pipe is clear. Then check the drum gasket. Behind the drum, there is a heater.The drum rotates and the heated air is passed from the stationary heater to the drum via a gasket, usually stuck to the back of the drum andthis rubs against the stationary heater wall. This gasket can become frayed or broken and bits can be ignited by the heater. The gasket will need to be replaced if this is the problem.
May 19, 2011 | Whirlpool LEW0050P Electric Dryer
Not generating heat and dosnt stop automatically
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101 ,..,
Apr 03, 2011 | GE Dryers
Dryer blowing cold air . No heat!
Check the "Bias thermostat" for continuity with a multimeter. IF it is bad, replace with this part.
Nov 29, 2010 | GE DBXR463EDWW Electric Dryer
Dryer does not get hot
There are a number of things that can go wrong on an electric dryer that will make it not heat...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 31, 2010 | GE DBSR453EBWW Electric Dryer
Jan 09, 2009 | Kenmore 64952 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
