Question about Toshiba Satellite A100-S8111TD Notebook
Will not power up for more than 1 second. Without battery installed, will not power up at all
  • 382 Answers
Sounds like battery is dead. Have you been having problems with power cord? When you plug in power cord with battery installed you should see a charging light. Maybe wiggle coord and see if you get some power. Toshiba, In my opinion is a great computer, but they do have a poorly designed power plug. They are forever being broken from the boards. I hope this helps and if it is a bad power socket, you can get them from Ebay for about $5. Good luck and have good day.
Posted on Feb 02, 2009
Battery is charged, but laptop cannot work without mains
You need to install a new power/sound board. These boards go dead on the early Intel MacBook Pros for some reason.
Oct 19, 2011 | Apple MacBook Pro - Core Duo 2.16 GHz -...
Can not trun my hp dv1217 notebook on even with the DC adapter.
1. Remove Battery
2. Remove all cables attached to the computer including AC Adapter
3. Hold on the power button for 60 seconds
4. Release power button and install the battery.
5. Power on the laptop
6. When Windows loads, attached the power cable
7. issue resolved.
Mar 04, 2011 | HP Computers & Internet
Acer aspire 6920 battery problem.. laptop only recognizes the battery and will not charge now... and only lasts a few minutes
1.Remove ,the battery and adopter from your machine.
2.And then press the power button form 36 Second.
3.And then refix your battery and adopter to your machine.
4.boot your system
1.first Instal the E-power management to your machine.(Didn't had means kindly download the application from our website www.acer.co.in.
2.fully charge your battery till 100% without any interption
3.now you work with your laptop untll it would be the 0%.
4.Kindly repeat the steps four times.
5.After that you Defently feel,your battery backup will increase.
Nov 16, 2010 | Acer Aspire 6920 Notebook PC
How do I reset the camera.
Hi.
1.Turn off the camera.
2.Remove any memory card installed.
3.Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
4.Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
5. Verify if the camera works without an optional memory card.
NOTE: Resetting the camera returns all settings to the factory defaults. Any images stored in memory will be retained.
Thank you for using Fixya!
Nov 16, 2010 | HP Photosmart M22 Digital Camera
Is the battery on the G-Shock MT-G recharge either by motion or sun light?
As you will see from the extract from the web site, these watches are solar powered.
" Tough Solar Power
  • Shock Resistant
  • 200M Water Resistant
  • 29 times zones (48 cities), city code display, daylight saving on/off
  • 4 Daily Alarms and 1 snooze alarm
  • Countdown Timer
    Measuring unit: 1 second
    Countdown range: 1 second to 60 minutes
    Other: Auto Repeat
  • 1/100 second stopwatch
    Measuring capacity: 23:59’59.99”
    Measuring modes: Elapsed time, split time, 1st-2nd place times
  • Auto Calendar (pre-programmed until the year 2099)
    12/24 Hour Formats
  • Accuracy: +/-15 seconds per month (with no signal calibration)
  • Storage Battery: CTL1025
  • Battery Power Indicator
  • Power Saving Function
  • Approx. battery life: 6 months on full charge (without further exposure to light)
    Module 5055"
Feb 03, 2010 | Watches
I cannot format the computer because the motherboards cd is gone, and the boot bios is blocked.
The CD is needed to install the drivers for the motherboard all the other utilities on it you can manage without. A getaround for you is to perform a backup your drivers onto a cd or USB memory stick and you can go ahead with your reformat.
Dec 30, 2009 | ASUS P4V8X-X Motherboard
PC suddenly lost power will not restart
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 05, 2009 | HP Compaq nx9010
I have a hp omnibook 4150 it beeps 1-3-3-1 but does not power up whats wrong
Dec 04, 2009 | HP OmniBook 4150 PC Notebook
My montitor on my laptop went off last night, after messing with the mouse for a minute, i shut it off, now it will not come back on. when i hit the power, the light on the battery button in the front...
1. Turn OFF the Computer, remove the Battery and disconnect the AC Adapter also.
2. Press and hold the Power Switch for 5 seconds.
3. Insert the Battery in the Computer an try turning ON the Computer.
4. If the issue persists, remove the Battery, press and hold the Power Switch for 5 seconds.
5. Connect the AC Adapter and try turning ON the Computer(without Battery).
NOTE: If the Computer turns on without the Battery, connect and charge the Battery for 24 hours.
6. Disconnect all external devices that are connected to the Computer.
7. Attempt to turn ON the Computer.
8. Remove any additional Random Access Memory (RAM) that was installed in the Computer.
9. Attempt to turn ON the Computer.
This should resolve the issue.
If the issue still persists, then service may requires to resolve the issue.
Nov 22, 2009 | Gateway M-6843 Notebook
Laptop fan spin for 2 second and display not show
You must veryfi the CPU and try without battery or try it without charger with a already charged battery! This must work!
Sep 13, 2009 | Lenovo 3000 N200 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
