My laptop is shutting down automatically because i installed windows vista updates . it completely filled my c drive . so every time when i log on it shows CONFIGURING WINDOWS then it shutdown and again restart continously. solve my problems please. my laptob is toshiba(sattelite)
Same problem: "configuring updates", "3 of 3 complete", "shutting down", keeps repeating, I try system resore, but on start up same all over again! Did anybody find the solution to this?Same problem: "configuring updates", "3 of 3 complete", "shutting down", keeps repeating, I try system resore, but on start up same all over again! Did anybody find the solution to this?
It might not help but sounds to me like it updated a lot of updates. You might have to let it keep starting and rebooting till it has installed all the updates.How do you know it filled your hard drive?
Insert the disc into the DVD drive in your computer.
The installation should begin automatically or give a pop-up asking you what you would like to do. Select Run Setup.exe.
Note: If the installation does not begin automatically follow these steps:
Click on Start.
Click on My Computer (Computer on Windows Vista and Windows 7)
Right Click on the DVD drive containing The Print Shop 3.5 disc.
Left Click on Open.
Double Left Click on Setup.exe.
The installer will now search your computer to make sure you have the required Windows Updates in order to install The Print Shop 3.5.
If it detects that you are missing an update the installer will prompt you to install these now. Once the updates are complete the installer will move to the next step automatically.
From here you should follow the on screen prompts to complete the installation.
Usually, after you re-install ... and set UPDATE mode (for Windows & IE) to automatic ... the system will look for and download updates (to Windows, browsers, etc.) automatically. So, shut down and restart ... and let it do it's (automatic) download & install . It may take quite a while, to bring you up to the latest Windows XP version.
that message is from the automatic updates windows makes from time to time ...and this message usually appears after a fresh install with the operation system out of date ..and if you have the automatic updates ticked for to be made automatically ..The thing to be done is either let it install the updates...and it will shut down by itself...or ..start windows..and go to control panel ..and on the automatic updates...stop the updating process..This will cause a message to appear in the tray system every time ..to warn you that your computer is out of date ..and so ...but it has no real distress cause it will run like a charm even without the updates...(probably even faster ..cause if your computer is a little limited in resources the updates will slow it down a little .. So ..this message is not a pest ..but the windows updating your operation system ..the only issue is when it is in error and takes more than the time it should ...usually it should not take more than a couple of hours for all 55 updates to be installed ...and this in case you have a slow computer...
Hi ahzeal,
One thing you can do that make some changes in automatic updates.
Just follow is these steps:-
1.Goto Start---->Run.
2.Type services.msc then hit enter.
3.Find out the Automatic updates or windows updates(in case of Windows Vista or Windows 7).
4.Change it to manual or you can stop that(Depends on your wish).
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Go to the Start menu and select Control Panel
In the search box, type in "update." Click on the link to turn automatic updating on or off. Select from the available options including the time you'd like updates to be downloaded and whether you'd like to be notified and asked before downloaded updates are installed.
1. Go to Start button > All Programs > Windows Update.
2. In the left pane, click Change settings.
3. Select Install updates automatically.
4. Under Recommended updates, select the Include recommended updates when downloading, installing, or notifying me about updates check box, and then click OK.
5. Make sure you click Check for updates to make sure your computer has the latest updates installed. You might need to shut down and restart you machine after the updates are applied.
What programs are installed on the machine? there may be a file that's conflicting with one of the updates. You may leave automatic updates turned off. Looking for the culprit will require and will be easier if a tech will check the computer onsite or thru remote access.
the exact same.
How is that possible to fill a whole drive whit updates?
Did u tryed to login in the safe mode?
If not, try that and delete some stuf on your C:drive to make space
Nic
