Question about Konica Minolta DiMAGE Z3 Digital Camera
Dimage Z3 lens does not retract
After leaving the camera in a handbag, I found the lens extended. Since I cannot bring it back to the shut down position. Any suggestion to solve the problem is welcome. Thank you
Check your batteries. Are they working? Try taking them out and replacing them. If you left the camera on when you put it away and the batteries drained, you won't be able to retract the lense until fresh batteries are inserted and the camera is powered up again.
Posted on Apr 19, 2009
Dimage z6 lens will not extend/retract after dropping. camera starts ok but then shuts down.
That would indicate damage to the lens motor or the extension tube. When the camera sees the motor using more power than normal it figures that the motor or the lens is sticking and shuts down to protect the battery and the rest of the power circuit.
That model should have a replaceable lens if I am thinking of the right one. If you take the lens off (twist the base ring about 45 degrees) then try starting up the camera. It should still fault but give a different error code. That would tell you if the problem is the motor or the lens tube. If its the tube just replace the lens. If its the motor then it gets tricky. The repair costs on this are a real **** shoot. On some models they will be worth doing and on others it will cost more than a new camera. So you need to check out the repair costs and get estimates and have a good idea of what a replacement camera is worth. Then you will know if its worth fixing or cheaper to replace.
This type of damage is very common on all cameras with retractable lens or hoods. They do try to build them to take a bit of abuse but sometimes that isn't enough to protect it.
Oct 11, 2010 | Konica Minolta DiMAGE Z6 Digital Camera
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Sep 25, 2009 | Samsung SL201 Digital Camera
Dimage Z3 won't focus
Fixed, after a thump on the carpet
Dec 19, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
Nikon L3 Lens wont extend
Hi:
If the camera has not been abused, such as dropping, impact of some sort, or restricting the extending lens, then there is an internal problem.
See my other posts on suggestions of selling it.
Nov 27, 2007 | Nikon COOLPIX L3 Digital Camera
I had this problem with my 600. I noticed that the end, center, part of the focusing mechanism was slightly out of alignment. (The part that usually sticks out furthest.) Once I straightened that piece, it was able to retract and the camera could be closed. Look at the focusing mechanism from all sides to make sure it is straight. The part was very slightly off, but enough to cause the error. My camera has been working fine since.
Aug 14, 2007 | Konica Minolta DiMAGE G600 Digital Camera
Camera dropped, won't zoom in or out, won't take pics
it has detected a mechanical restriction that is severe enough for the micro to "time-out" and shut down to prevent further damage.
Jun 03, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
What is the focusing range of the DiMAGE Z3?
Wideangle: 0.6m to infinity (from lens front) / Telephoto: 2.0m to infinity (from lens front) Wideangle: 0.685m to infinity (from CCD) / Telephoto: 2.085m to infinity (from CCD)
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
148 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
