Pc crashes all the time,i installed 2gb of ram
What kind of RAM did you install? If the RAM should match the speed-limits of your motherboard. So if your RAM speed is, say, 667MHz and your board will only use 400MHz or 533MHz, you will need to get the correct speed. Check your user guide for the correct specs of memory for your particular model systems. Good Luck.
Problem: More than 2GB of RAM is installed, yet the 32-bit OS only sees 2GB.
Cause: Memory remapping is enabled.
Solution: Enter Computer Setup (F10) and disable memory remapping: Advanced > Chipset/Memory.
How many sticks of RAM are in your system at the time? What types of memory are they?
Did you install the correct type of memory? If so, you may have a defective stick of memory
