Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error: ink absorber full. Does not print or scan. Ink cartridge doesn't move.
Error on the Canon printer/scanner MP160 says: ink absorber full. The "machine" does not print or scan. When the hood is opened, the ink cartridge doesn't move. We have to manually pull it over to check it. What is the relationship between the printer and the machine used as a scanner? In other words, how can we use it as a scanner alone? Also, when the cartridges are "examined" on the back side, there is too much extra ink showing. Also, on the machine itself, it shows a E27 error. What does this mean?
  • 1 more comment
  • malhayatawo Feb 05, 2009
    sAME PROBLEM, Ink absorber is full, I manually cleaned the absorber, but the cartridge still wont move, It showed Error 2 and 7.It does not print..By the way, I replaced the cartridge and still wont print
  • issi640 Feb 05, 2009
    Where is the answer to this question?
  • Carlos Perez
    Carlos Perez May 11, 2010
    i have been reading some issues related to full wasteink tank.
    wel before continueing i want to state that my space bar is not properly working Lol so if you see some words together you know now why
    anyways, since i haveread some threadsabout the full waste ink deposit i have gotten a question for you (curious,huh) how do you know the waste ink deposit is full? i mean....as fas as I remember this machines dont 'tell you' the ink deposit is full....so...how did you allcome to that conclussion?? cause as amatter of fact the waste ink absorbers are underneath the paper pick up mechanism... so they are not even easy to see... about the error code i willgive you that answer tomorrow cause today i didnt go to work since i have been seriously sick... you say it flashed E,2,7 right? anyways, in order to get rid of the full ink absorber problem you not only needto enter service mode but also to reset the machine, and for that you actually need a canon special software that i dont think is actually available over the net, will have to make a good research about that. the relationship between the fullink abs and the scanner is that this problem blocks the whole machine and no it will not let you even scan with this situation. so i will find out in the next hours if there's an alternative way to reset cause as far as im concerned you will need (as i said before) that special resetting tool only available at canon authorized agencies.
How to solve problem E27?
Posted on Feb 05, 2009
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
How to fix error 24 for mp 160????
Hi
This is a purge unit error hence you need to check and make sure the purge unit is working fine. If not you need to clean it.
THE PURGE UNIT IS THE ONE ON THE RIGHT SIDE WHERE THE CARTREIDGE RESTS WHEN YOU TURN OFF THE PRINTER.
And at the same keep the below mentioned error list for your future use.
CANON MP140, MP145, MP150, MP160 ERROR CODES RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E3-3 = Paper jam
E4 = No ink
Direct Printing
E29 = EEPROM error
Jul 31, 2011 | Canon PIXMA MP160 All-In-One InkJet...
What is E4 on Printer MP160 please?
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
hope it will help..
Apr 25, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I am trying to print and my Canon MP160 is flashing 2 and E. I cannot print what can I do
This is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
YOU CAN TRY THIS:
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Hope this helps,
Good Luck
Mar 11, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber full so printer wont print
yes, printer wont print and see screen message
Use this method below with your own risk!!
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
Direct Printing
E22 Carriage error
E29 EEPROM error
Use MPTOOL to reset waste ink absober full on pixma mp160.
Download your Mptool first http://www.ziddu.com/download/8524406/MPTool.rar.html
Download manual guide how to use Mptool on pixma mp160.
http://www.ziddu.com/download/8525856/mp160manualguide.pdf.html
Hope this can help......
Jul 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
ERROR E 2 comes up on the little lcd screen when i try to print now.
www.fixyourownprinter.com
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 26, 2009 | Canon PIXMA MP160 All-In-One Printer
E3 flashes when turned on
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-1
Feb 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Waste ink absorber is full, waste ink full, waste ink absorber, a
may the error code or how many blinking can solve your problem
this is the list of error code
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
try this methode
Methode 1
button pressing
procedures below.
procedures below.
that's all
maybe it can fix your problem
thanks
Jan 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E5 and 2,114,0 errors on Canon MP160
Empty cartridges may cause this error. Here is the error code list for your printer
E3-3 = Paper jam
E4 = No ink
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E16 -E19 = Failed to scan head alignment sheet
E29 = EEPROM error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
241 people viewed this question
old marine
old marine
