Question about Dryers
Help dryer will start but after 5 minutes will shut down
  • 547 Answers
Replace timer
Posted on Feb 11, 2009
Dryer LG 1100 shuts off after a few minutes. If you set it for 54 minutes, you check if after 5 minutes it reads 14 minthen in 5 minutes it starts cooling down. The clothes are still wet.
Clean your lint filter, and clean the entire line vent from the dryer to the outside export port, also look inside the dryer vent hook up for obstructions and remove any lint. Keeping these parts lint free will save you energy and also drying time and maintenance repairs. My dryer is 18 years old.
Sep 29, 2015 | LG Dryers
Shutting down power on my fridgidaire 2008 dryer that stops and lights start flashing
without make/model we have a real hard time looking for a solution
Mar 22, 2015 | Dryers
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
Electric dryer keeps stopping
Most likely, the operating thermostat has failed, and the high limit thermostat turns off the dryer when it gets too hot. When it cools down, it will start again.
Apr 06, 2010 | Whirlpool GEW9250 Electric Dryer
DRYERS RUNS FOR ABOUT 5 TO 10 MINUTES THEN STOPS FOR ABOUT 5 MINUTES THEN STARTS BACK UP AND RUNS FOR A 5 TO 10 MINUTES .
sounds like your hi-limit temp switch is getting bad,its located on the heating element case to shut-down the dryer element so it doesn't overheat and cause a fire, they can cause problems
Aug 22, 2009 | Dryers
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Dryer shuts off after 15 minutes and needs to cool down then will start again and the cylec continues!!On, off,on, off.
The problem is more likely a high temp limit switch. I don't have a schematic of your dryer, but one should be included somewhere on the dryer. You have to use a voltmeter to test the components in the circuit. The thermostat controls the heat temp, you may want to start there
May 07, 2009 | GE DVL223EBWW Electric Dryer
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Dryers Logo
Top Dryers Experts
