Question about Refrigerators
Light switch does not work
Sub zero 532  light switch on right door does not work, how do i fix this?? thanks
  • 1 more comment
  • bentom Feb 02, 2009
    this is not what i need
    i need to know how to take apart the panel the holds the switch so i can replace it
  • Bocaboy Mar 02, 2009
    I have the same problem, and jiggling the left switch (the lightswitch) will usually bet the light to come on. I'd like to replace itbut don't know how to remove it. Does it just pry out? I don't see anyway to get to it from above for the side. My SZ was manufactured in1988 and is still going strong, except for this problem.
    Thanks.
  • Anonymous Apr 27, 2009
    Don't know how to get to the bulb...
1. Check to see if the bulb has blown.
2. Check the plunger switch is making contact. ( the light must be on when the
door is open meaning that the plunger is sticking outward. the light should go
off when you press the plunger in)
Posted on Feb 02, 2009
Freezer fan not working - Sub zero 532 -
usually this is because the fan is clogged with ice and has frozen ice stopping it from spinning otherwise if you see no ice blocking the fan from spinning see the link below and purchase new fan and replace it.
Sub zero 532 fan Google Search
Feb 16, 2018 | Refrigerators
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
Sub zero refrigerator model 532 problem the freeze is warm on the top but the ice & items below the ice are OK. i suspect that the light may be always on. also the freezer door does not make its...
I suspect a bad fan motor, door switch, or not defrosting.The suction when door closes is caused by the low temperature created when working properly.
Feb 14, 2010 | Freezers
I have a sub-zero model 532 where the fridge lights will not come on. I replaced the bulbs alll 4 are new. The freezer lghts still work.
The ref. door switch may be at fault.
Flip the switch several times and see if the lights come on.
If so replace the switch.
Also if the grille on top is removeable check and see if the wires to the door switch are disconnected.
Jan 15, 2010 | Refrigerators
Power requirement sub zero 532
115 volts on a 15 amp circuit
May 19, 2009 | Sub-Zero 632 / S
SubZero 532 frig lights out
There are two door switches one for fan and the other for the lights. With the compressor running, there are two so yu need to make sure it is the refrigerator and not the freezer, open the door and press the right switch and listen for a fan. The left should be your light switch and the problem is generally in the switch, on rare occasions there is a failure of bi-metal safety switch part number 4200850. One very rare occasions you may have a wiring proble.If you go to www.subzero.com there is a showroom locator tab on the top right corner, click it and you will go to a locator page which will get you to your local parts didtributor.
Nov 30, 2008 | Sub-Zero 561 / F
Sub zero 532: noise increasing.
We have the same SubZero unit and the water leak is the ice maker line or the pan that catches condensation. If you unscrew the panel at the bottom, you will be able to take the pan out and see if the water is from there. If it is from the ice maker line (which was plastic on ours), you should fix this right away as we didn't and we ended up having a $10,000 flood that ruined our hardwood floors. Also, the increased motor noise happened to us as well, but when we had the motor replaced, it is not much quieter.
Nov 15, 2008 | Sub-Zero 632 / S
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Refrigerators Logo
469 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
