Question about HP Photosmart D7260 Printer
Photosmart D7260 does not sense Paper in maintray
My HP Photosmart D7260 printer says I am out of paper. There is plenty of paper in the main tray. I have replaced the paper and get the same report. Still will not print
  • 3 more comments
  • dcortes893 Feb 12, 2009
    I have the same problem. I tried adding one sheet at a time or just a few at a time. I tried adding more. I took out the paper and adjusted it. Nothing works. This machine is useless!
  • GadgetGuyTN Feb 28, 2009
    I have the same problem. My paper tray is full but the printer will frequently report that it is out of paper. I have yet to find a solution to this problem.
  • icaper0309 Mar 15, 2009
    Printer continuously says it is out of paper. I pull the tray out,push it back in and I am good for one or two more sheets.
  • Anonymous Apr 08, 2009
    Same thing: VERY frustrating.
    Note: new HP photo papers have VERY course backings (almost sandpaper) to them; they work. Looks like the co. is trying to sell paper.
  • dagallun Apr 22, 2009
    The printer does not feed paper from the main or the photo tray. It gets sporadic use - bought it less than a year ago - new - at Office Max. Prints high quality pictures but if the useful life is under 1000 prints it has a serious design flaw.
    Is there a reasonable/reliable fix?
I had the same problem. I hadn't used the printer in a long time and it took a few minutes to figure out what I did. This may not be your problem, but there are two sliders on the main tray. The first goes left to right and the second goes front to back. If you've use normal 4x6 paper you put the paper in and push the slider forward to lock in the paper so it prints straight. The problem is if you run out of paper and haven't used the printer in a long time, you may try to slide the paper in just like you would a normal printer. But for it to work, you have to pull the front-to-back slider back, and make sure the paper is forward of that slider. If you've pushed it way forward after trying to shove your paper in, you may have to find something to pull it back out again, because your fingers might not be able to get in that far.
Posted on Jul 12, 2009
I pulled the main input tray out- how do I put it back
Try looking at HP's page on your model here:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=65515&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3315742
Is it a 'carriage jam' or an 'out of paper' error?
The paper input tray on your machine should go back in similarly to a kitchen cabinet drawer. Lift up slightly and push in, and it should slide back into place.
Mar 15, 2013 | HP Photosmart D7260 Printer
Out of paper tray has paper
remove the use a flash light to look at the lever that senses that the paper is in the tray. That probably means that the plastic lever that senses the paper. It might be stuck, off its lever.
If that is not it, then maybe you have a sensor or motherboard issue. Make sure the entire paper tray is pushed in or it will act that way. There are like 3 sensors that have to be activated in order to think it has paper.
E
Nov 23, 2011 | HP Photosmart C6280 Printer
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
I am unable to print photographs on my D7260 HP Photosmart Printer bacause the blank photo papers are not being drawn into the machine
Have you loaded them face down? I have a 7360 and they are pretty fussy about what they will take and what they won't and how. The paper must be put in the upper drawer (if it is 6x4 paper), with the glossy side down and the drawer must be pushed right in.
Jun 12, 2009 | HP Photosmart D7260 Printer
With HP Photosmart D7260 Printer, I get "out of paper" error, paper tray full, feed rollers leave skid marks on paper" I have tried other paper (HP Premium Ink Jet paper, Avery namecard stock, HP Premium...
Perhaps you are loading too much paper into the tray. Please try to work through the steps in this troubleshooter and see if it has any effect. If not, please report back with the results and someone will be happy to assist you.
HP OOPaper
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | HP Photosmart D7260 Printer
Pictures will not print and paper will not load for printing pict
You need to push the paper through just touching the boundary of the printer paper tray
Feb 12, 2009 | HP Photosmart D7260 Printer
Hp photosmart pro B9180 does not sense paper
Hello sir; You need to clean paper pick up roller, and rubber pad(right underneath the roller) as well as paper sensor.
Jan 12, 2009 | HP Photosmart Pro B9180 InkJet Printer
HP Photosmart c5180 Paper Feed Problem
first of all power off printer
then after back side open tray. and clean all dust.
some time paper are jam or cut their so, printer sense paper still in their.
so do this u can printer again easy.
Nov 09, 2008 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7260 Printer Logo
304 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
