Question about Acer Aspire 6930-6082 Notebook PC
Region free for laptop.....( how..?)
I have an acer aspire 6930G wich has blue ray.
I watch my movies through arcade deluxe. However, some dvd's i have don't play b'cause of the damn region code's. it will only let you change this up to 5 times as you may know. It is already set at region (A) (2)
Standard CD rom drive-Optiarc BD ROM BC-5500S
Is there any way i can make my laptop multi-region???
  • mgayur May 11, 2010
    whit skirin problm leptop 4710 acer on and of
I need to download Acer Arcade Deluxe for Acer Aspire 6930G as I deleted it.
Hi, you can download the files here:
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=571
Please select your operating system 32 or 64 bit.
And unzip the file before installation.
Sep 25, 2011 | Computers & Internet
How to play Blu-ray movie on 5536G?
Arcade Deluxe is nothing more than a **** media center with a useless media player in it - get rid of it. If you want to play BR disks there are 2 options: either install a good codec pack like http://www.free-codecs.com/download_soft.php?d=5748&s=775 an use WMP or install and use VLC http://www.videolan.org/vlc/download-windows.html
Jun 11, 2010 | Acer Aspire 5500 5570-2609 Laptop
My Acer 6920G will not play Blue Ray DVD'S. I am unable to get helpful info from Acer. Tried to find a Driver to download with no sucess. Would greatly appreciate help
You also need a patch from Acer,
http://www.cyberlink.com/prog/oem/acer/update/index.jsp
Acer Arcade Deluxe v1.13.4806
Go to acer arcade deluxe
select "Play Movie"
Select "settings"
select "BD settings"
Select "region code"
Select "region B" for the UK
Important Note!:
You can only change your region !!! 5 !!!! times!
that is 5 times!
I am totally stressing this.....5 times!
You may have to do this a second time so your computer locks on to this region code.
If you watch an american blu-ray vid, on the fifth change of the region code your computer locks to this region !FOREVER!
SO I AM TOLD.
Feb 26, 2010 | Acer Aspire 6920 Notebook PC
DVD drive ''Free'' Region code does not play Region 1 DVD
You cannot see region 1 movies unless you change the region code, its designed this way as an anti piracy measure.
Oct 03, 2009 | Computers & Internet
When I try to launch a Blu-Ray movie Acer Arcade Deluxe attempts to connect to what I guess is a non-existant web site which it fails to do. This is the end of your movie playing experience. There is no...
Ok I,m not sure i can solve the problem for you, but have had problems with my acer 6920 G. Hopefully this will help. I was playing blu ray discs on my acer 6920 G wich i believe has the same sony/nec Optiarc blu-ray player. It was playing blu rays fine for a while. then as newer and newer releases were coming out it would not play some blue rays from certain manufacturers (Fox). Then newer releases from other manufacturers would not play. I was getting updates from acer arcade deluxe that would allow me to play some of the newer releases. The only problem i was having was that the updates (patches?) were not keeping up to the newer releases. The last update from acer was corrupted or somthing was wrong with it and then my blu-ray player wouldn't play anything at all. To solve the problem I reinstalled acer arcade deluxe using the acer e recovery management. This fixed the problem. But now back to square 1. My older blue rays will play but not the newer ones. I've been going over this problem for a while now. The Acer site was no help at all. The e-mailed me some solutions both hardware and software but weren't even close to what the problem is. You can try Cyberlink Power DVD 8 and it runs better than the Acer Arcade Deluxe. (They write the updates for the acer arcade deluxe) It is expensive the last time i checked. Hope this helps a little.
May 01, 2009 | Computers & Internet
Acer Aspire 6930 won't play Blu Rays
Your DVD is not Blue Ray capable. You would need to purchase a Blue Ray DVD player for your laptop, just having the software does not allow you to read them.
Apr 11, 2009 | Acer Aspire 6930-6455 Notebook PC
I have an acer aspire 6930G, it is windows vista and has blue ray. My Problem: i bought a blue ray dvd and when i put it in the drive it told me i cant play the dvd unless i change my regionl code to b or...
Yes get a program called "any dvd" I use it in all my machines, it will allow you to play anything on your machines. it's made by a company www.slysoft.com , it is very cool and you will be able to play every region coded or decoded disks anythig, have a good day. if you do a google search, I have even seen it being given away, but it's not expensive, And it lasts forever with updates , and it does blue ray. and HD
Dec 21, 2008 | Acer Aspire 5100 Notebook
My blu-ray player on my acer aspire 6920 isnt reading a blu-raY MOVIE I JUST BOUGT
i`m pressuming you are in the uk ? if so !
select "Play Movie"
Select "settings"
Important Note!:
that is 5 times!
Dec 21, 2008 | Acer Computers & Internet
Acer Aspire 6930-6082 Notebook PC Logo
639 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
