Question about Lincoln Electric LINK2400-+2 CV-305 MIG Welder with Options Input Power: 23
Connect ln 9 gma to miller xmt 304 inverter with 14pin recep.
I have 9pin to 14pin control cable but am getting no power to mig.
have checked circut breakers
    President:
  • 2,976 Answers
One of your pins isn't wired correctly for your combination.
Posted on Feb 12, 2009
I have a HEL p-6 code on a xmt 304 how do I fix it
Sounds like a input power problem . Make sure voltage is correct coming to the unit and wired correctly. I checked a Miller welder recently ,auto link that would come on and weld but not good . Took cover off and it was wired wrong .
Dec 08, 2014 | Welding Tools
Burning up tips fast with Miller S-22A
tooslow and probaly too close to work piece try turning heat down a little also make shure you have a good ground/ maybe angle your gun a little more
Dec 17, 2012 | Miller Welding Tools
Xmt 304 it shows PPP PPP when in the mig selector
There were a couple options with that model, each with it's own manual.
Generally speaking though, the issue should localized to the switch- a wire may be broken, or if the unit has not been cleaned out/blown out with dry compressed air, it may simply be dirt, especially if the machine acts as if in pulsed mode for all of those settings. If no "HE.L" codes appear, I would look for a short in the switch, meltted wires, shorted wires, or the switch contacts themselves may be dirty and need some contact cleaner. If you have the model with an inductance control, make sure to spray that as well. Look for a small opening into the control to direct the spray.
If you do not have the manual, you can get it here for free:
http://www.millerwelds.com/service/ownersmanuals.php?model
While it is possible to service the circuit boards at the component level in the event of a component failure, parts are sometimes just not available, but that does not mean they cannot be serivced, just that you may need to canibalize another machine for certain pieces and parts. However with that said, most of the potential board failures would trip one of the "HE.L" codes..
Oct 28, 2012 | Welding Tools
I have a miller xmt 304 i bought it used. i have a 12vs wire feeder on it and im not getting power to it. any suggestions on what the problem could be
Hi:
Ok, let troubleshoot this one.
There is only two connectors on your 12VS wire feeder; the lead cable that goes to the + side of the XMT welding machine and the VS cable (Volt Sensing) that goes to you work piece joining the ground cable (don't forget the ground clamp).
a) The mode switch on your XMT must be on V-sense feeder.
b) Your 12VS feeder depending on what kind of wire you are using (innershield) negative side or gas wire + side.
That's it. If there i no spark, there is something wrong with your XMT.
If this was useful to you please vote. Thanks.
Apr 01, 2011 | Welding Tools
When im welding the xmt 304 machine will arc out and the volts will say HE.L and the amps will say P.5 its like it loses ground what does the volts and amps mean when it says that.
Help 5 Display Indicates the right side of the unit has overheated.
The unit has shut down to allow the fan to cool it. Operation will continue when the unit has cooled.
If unit overheats, output stops, a Help 5 message is displayed, and cooling fan runs.
Wait fifteen minutes for unit to cool.
To avoid this problem Reduce amperage or voltage, or duty cycle before welding.
Jan 22, 2011 | Miller Welding Tools
Lincoln Electric LINK2400-+2 CV-305 MIG Welder with Options Input Power: 23 Logo
292 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
