Question about Lexmark C532dn Laser Printer
We have a Llexmark C532dn with a PC unit life warning showing. We have changed all the cartridges but we still have this warning appearing. Could you kindly help us identify this problem, thank
You have to replace the Photo conductor
Posted on Feb 25, 2009
What does PC life warning mean - message on Dell 2350dn?
it could be that the cartridge is nearing the end of its serviceable life, I assume PC stands for Printer Cartridge. You could try getting it serviced
Feb 12, 2015 | Dell Office Equipment & Supplies
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
PC life warning on Lexmark e360dn
You need to change the photo conducter... its the 2nd tray that pulls out under the toner cartridge I think its a green handle same as toner
Jul 27, 2012 | Lexmark E360DN LASER PRINTER N Laser...
The toner tray will not pull out from the machine
Replacing the Toner Cartridge
The MFC can print up to 6,000 pages using a high yield toner cartridge. When
the toner cartridge is running low, the LCD shows TONER LOW. The MFC is
supplied with a standard toner cartridge that must be replaced after
approximately 3,000 pages. Actual page count will vary depending on your
average document type (i.e., standard letter, detailed graphics).
Discard the used toner cartridge according to local regulations. If you are not
sure of them, your local Sanitation Department. Be sure to seal the toner
cartridge tightly so toner powder does not spill out of the cartridge. When
discarding used toner cartridges, keep them separate from domestic garbage.
We recommend that you clean the MFC when you replace the toner cartridge.
1 Open the front cover and pull out the drum unit.
Place the drum unit on a drop cloth or large piece of disposable paper to avoid
spilling and scattering the toner.
2 Hold down the lock lever on the right and pull the toner cartridge out of the drum
unit assembly.
Caution
Handle the toner cartridge carefully. If toner scatters on your hands or clothes,
immediately wipe it off or wash it with cold water.
3 Unpack the new toner cartridge. Place the used toner cartridge into the
aluminum bag and discard it according to local regulations.
 Wait to unpack the toner cartridge until immediately before you install it in the
MFC. If a toner cartridge is left unpacked for a long period of time, the toner life
is shortened.
 You can use only a genuine Brother toner cartridge (TN-430 or TN-460), which
is specially formulated to ensure top print quality. Using another brand of toner
cartridge may void your MFC’s warranty. Warranty coverage does not apply to
problems caused by the use of 3rd party Toner, 3rd party Toner Cartridge or 3rd
party Drum unit.
4 Gently rock the toner cartidge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place.
7 Clean the primary corona
wire inside the drum unit by
gently sliding the blue tab
from right to left several
times. Return the blue tab to
the Home position ( )
before reinstalling the drum
unit assembly.
Reinstall the drum unit and close the
front cover.
Replacing the Drum Unit
The MFC uses a drum unit to create print images on paper. If the LCD shows
CHANGE DRUM SOON, the drum unit is near the end of its life and it is time
to purchase a new one.
Even if the LCD shows CHANGE DRUM SOON, you may be able to continue
printing without having to replace the drum unit for a while. However, if there
is a noticeable deterioration in the output print quality (even before CHANGE
DRUM SOON appears), then the drum unit should be replaced. You should
clean the MFC when you replace the drum unit. (See page 21-18.)
Caution
When removing the drum unit, handle it carefully because it contains toner. If
toner scatters and your hands or clothes get dirty, immediately wipe or wash
with cold water.
WARNING
Just after you have used the MFC, some
internal parts of the MFC are extremely
HOT! So please be careful.
The drum unit is a consumable item, and it is necessary to replace it periodically.
There are many factors that determine the actual drum life, such as temperature,
humidity, type of paper and how much toner you use for the number of pages per print
job. The estimated drum life is up to 20,000 pages. The actual number of pages your
drum will print may be significantly less than these estimates. Because we have no
control over the many factors that determine the actual drum life, we cannot
guarantee a minimum number of pages that will be printed by your drum.
Oct 02, 2009 | Brother MFC-9840CDW Laser Printer
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
Signal on screen ''life warning''
AFTER CHANGING DRUM KEEP DOOR OPEN AND HOLD THE CANCEL BUTTON FOR 5 OR 10 SEC. IT WORKED FOR ME
Apr 13, 2009 | Dell (2333R) Motherboard
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Nov 26, 2008 | Lexmark C510 Laser Printer
Lexmark C532dn Laser Printer Logo
225 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
