Question about Sharp AL 800 Copier
Error code of H 4 flashing on screen
I have a Sharp AL-800 digital desktop copier. It has been constantly flashing H and then 4. I unplugged it.. Checked for jams- etc. etc. I can't figure it out.
Can you help??
Thank you!
Brian Conlin
  • tmsol87 Mar 15, 2009
    Pretty much the same as another person's. The H 4 keeps flashing, unplugged the machine, entered a code they said to do when we called sharp and then the machine was unplugged for quite some time and now we plugged it back in, same problem.
Change fuser assembly
Posted on Feb 03, 2009
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
Sharp AL-800 is blinking H and 4 what could be the problem?
the error code H4, means that an abnormal temperature was detected in the fusing section (the hot roller was not working properly during the initialisation of the printer), to solve the problem;
  1. unplug the printer from the power source
  2. wait for 10 mn
  3. plug the printer again to the power source
  4. switch on the printer
if the error H4 still displayed, you need change the fixing unit, that must be doing by a qualified technician,
Dec 14, 2010 | Sharp AL 800 Copier
What does E7 Error code mean for SHarp AL-800 copier?
?7 03 Problem related to the brightness of the laser emission 04 Error in determining the level of white in the performance of hatching 05 Error in determining the level of black during hatching 12 Error output level in the performance of hatching 14 Failure ASIC (MCU PWB) 15 Trouble copying lamps
Sep 19, 2010 | Sharp AL 800 Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Upon startup (Sharp AL-800) I keep getting an E-7 Error Code. Just prior to this problem I was attempting to change the exposure adjustment setting and may have pushed too many buttons (or the wrong ones)....
Try turning the printer off, and then unplugging it from the power supply. Leave it unplugged for about 5 minutes and then plug it back in and power it up. This may clear the error code.
Also, try pressing the COPY key when the error code comes up, there may be a sub-code that will be displayed and provide more information about the cause of the error.
Jan 24, 2010 | Sharp AL-840 Laser Printer
Error message E 7
Try these steps to cancel the error, press the buttons continously
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not, do again step 1 until the display turns off. 14 then press print button
Jan 29, 2009 | Sharp AL 800 Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Code L 100
An L100 would cause that error code. there is a scanner lock located to the left of the machine.
Jul 14, 2008 | Sharp AL 800 Copier
Sharp AL 800 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
