Question about Broan-NuTone L700L In-Line Exhaust Fan Kitchen Hood
Fan Motor This motor is in the bathroom in a major company. We need one real bad. How do i get one here tomorrow?
  • 10,865 Answers
They carry Nutone at Home Depot. If you have a HD near you go and pick one up. Good luck.
And please rate my answer. Thank you.
Posted on Feb 03, 2009
Need motor for Fantom FM741H
Fantom is kind of an odd company to get major parts from. What I would recommend is take the motor out and see if its made by a major company like Ametek and get it through them. Or, a donor machine perhaps.
Nov 27, 2017 | Vacuums
Exhaust Fan does not work
Motors are divided into many categories. Most bathroom fans use a shaded pole motor (having a transformer on one side, a laminated yoke and 2 circles of copper shorting around the laminations to create a north and south pole) Another type is a compound wound motor (having brushes) A third type is an induction motor. the rotor of the motor is a series of laminations where a magnetic frequency in the stator windings induce magnetism in the rotor and they repel each other. A squirrel cage capacitor start induction run has a large capacitor on the side.
You can not mix and match what you want from one motor style to another motor style. If you have a brush type motor, perhaps the commutator needs cleaning and the commutator could be shorted with metal filings. The brushes may have failed and needs replacing. The bearings may have seized and the windings heated up blowing the thermal cutoff just under the tape of the windings. The windings may have burned through the varnish that coats the wires on the start winding (on motors with a centrifugal switch only) Centrifugal switches can fail to open or close. Only someone knowledgeable with motors can tell you what you have and what the problem is. It is far cheaper to replace a motor with a similar one on inexpensive devices such as a bathroom fan. A new fan may be cheaper than getting a new motor.
Nov 13, 2013 | Dryers
Replacement Motor for Bathroom Exhaust Fan Need motor and blower assembly or just the motor for a Sears Roebuck Model 864.892 Motor is Universal Electric Co Model 118JF5 S/N 1T26714
Not sure what you are asking, but you can get a replacement directly from Sears. It is okay to replace just the motor, but be sure the fan blades are completely cleaned. When you are all done, verify good air flow outside of the building.
Sep 19, 2010 | Home
Nu Tone Bath Exhaust Fan - QT-110N-B - motor vibrating
You can buy just the motor assembly. You would remove the grill. Usually there is a plug to disconnect the motor. Remove screw(s) and the motor and fan assembly will come out leaving the rough in housing in the ceiling. I did not locate your model number as you listed it however the QT line has numerous model numbers. Here is a link to the nutone page. You should be able to purchase a "trim kit" which would include the fan,motor,and grill. You can either buy it on-line, or you might try an electrical supply company.
Jul 05, 2010 | Home
Fan unit does not come on.
if im reading this correctly,you need to push start your fan motor?
Either the motor start capacitor is bad or the motor windings are bad.
If the motor is not coming up to full speed or is faulty you will not get good cooling.
Sounds as you may need a new motor.
Jun 01, 2010 | Ruud Central System Air Conditioner
How to oil a broan bathroom fan motor
The fan motor is pre-oiled and sealed so it can not be oiled if fan motor is squeeling then motor replacement is the only option. You can get replacement motors which is usually cheaper than buying a whole new fan. Will need to know the model # of broan fan. I hope this information was helpful. Please rate the information given. Good Luck and have a great day. Jeff
Apr 02, 2010 | Home
NuTone bathroom fan starts slowly after being off awhile
need to blow it out with a air hose and oil it real good! but keep a eye on it to make sure it does not get hot! if it feels hot to touch replace the motor!
Nov 03, 2009 | Broan-NuTone (668RP) Fan
Bathroom exhaust fan 16 years old and noisy. How to fix?
One drop of 30 wt oil at each bearing will quiet the thing for a while, but you will eventually want to replace it. Also consider the whole fan is about the same cost as the motor, and easier to find.
May 16, 2009 | Broan-NuTone N-671R Exhaust Fan Exhaust...
Motor for bathroom exhaust fan
same problem but l thing l solved it by ordering a new replacement from if you need more help email me at
Mar 01, 2009 | Marley PJ1257 Heater
Broan-NuTone L700L In-Line Exhaust Fan Kitchen Hood Logo
103 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
