Question about Dryers
Drum Loose on Kenmore 70 electric dryer
My dryer was giving a buzzing noise and cutting off mid cycle. Following instructions from this forum (which were excellent by the way), I disassembled, cleaned the motor endbells, realigned the tensioner, and reassembled the dryer.
Everything seemed fine, but now it seems that the drum will come "off track" when I turn it manually from inside. The dryer will run fine.
I've double checked and everything seems to be reassembled correctly. But I'm pretty sure the drum shouldn't come "off track" like this.
What have I missed?
  • 25 Answers
Don't turn by hand
Posted on Feb 12, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Kenmore 70 Series Electric Dryer will not start
It sounds like the hi-limit thermostate and/or the thermal cut-off is what is causing your dryer to shut down. Basically it's over heating. You should replace these two items togeather. Also the thermal cut-off will be triggered by a grounded out heating element. Here is a diagram of where these items are located. hope this helps
Figure W-6: Dryer Rear Access
Feb 27, 2012 | Dryers
Kenmore 70 series dryer makes buzzing noise and stopped working
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Kenmore 65942 Electric Dryer
Whirlpool Supreme Dryer rumbles while turned on then stops mid cycle. When I push the start button I hear a buzzing noise, then a click and then silence. After the dryer sits for a while, it will start...
Chances are it's the drive that drives the belt around the drum, or the motor is on its way out. Have a technician inspect the belt/belt drive system as well as the motor.
Jan 29, 2010 | Whirlpool LER4634J Electric Dryer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore dryer 60 series won't turn on
YOUR MOTOR HAS FAILED,IT IS TO WEAK NOW TO TURN ON,YOU CAN GET THE DRYER MODEL NUMBER INSIDE THE DOOR AND GO ON EBAY TO SEE IF YOU CAN FIND ONE-MIKE
Feb 28, 2009 | Kenmore 63942 Dryer
Whirlpool gas dryer makes buzzing sound when started, stops mid-c
Maybe something fell down into the filter housing. Get the back off and inspect it with the power disconnected.
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Kenmore Electric 70 series dryer making noise
can spin motor w/ hand ,,if so pull side by side if no noise ,, inspect rollers,and idler
Dec 28, 2008 | Kenmore 65942 Electric Dryer
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Dryers Logo
128 people viewed this question
Top Dryers Experts
