Question about Garden
Chainsaw doesn t start because is cold
It is very cold right here at the moment so i am having problems satrting the chainsaw, i have tried to ajust the screws with the sun label and snow label just near the handle but as i have misplaced tthe manual really don t know how it works. thanks.
    Sergeant:
  • 359 Answers
Give it a shot of starting fluid and see what happens , should start
Posted on Feb 02, 2009
Homelite chainsaw model ut10580a
First place to start is replacing the fuel filter in the fuel tank, hook the hose out through the open filler hole with a piece of bent wire, replace the filter on the end.
May 07, 2013 | Garden
Hitachi CS33EB won't start when hot solution?
see if you loosing spark when it doesn't start
Aug 10, 2012 | Hitachi Garden
Want to know what the button on the top right corner of the saw is meant for ,often while cutting my left thumb seems to hit this and shut the saw off. There is a little diagram beside the button by I...
The only button i can think of is the decompression valve, but i did not think it possible to hit this while operating the saw, this button is a starting aid, you push it in to satrt the saw, when the saw sarts it will come out automatically, if you push it in with the saw running it will stop.
Apr 01, 2011 | Garden
Fuel ajustments on carberetter
to ajust your fuel inlet their is a screw on the side of the carb when you screw it in your leaning it out and out will richen it but you need to find the right ajustment because if to lean it out to much you will burn the piston but to rich will foul the plug
Feb 24, 2011 | Garden
I have a MAC120 and not keep it running. Starts but shuts off right away. Checked the carb. and everything seams OK. Use high test gas.
hi i have a mac120 but when running its using too much chain oil is there an ajustment screw to turn it down somewhere?
Jan 24, 2011 | McCulloch Garden
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Same problem with rinnai V1200.starts ok and as soon as you want to ajust cold water,the hot water line gets cold.**** all design
These units need water flow/pressure to work. If you use a mixer to get the right temperature as soon as you try to increase cold to make the water colder you unfortunately reduce the hot flow. Fairly complicated fault to explain, all continuous flow units have the same flaw. Solution is to try and increase flow and the best way is to take any water filters or restrictors out of your tapware. Most taps have the located in the end of the spout. Unscrew the end and remove any restrictors. Shower roses are a bit more tricky to find. This fixes 99% of these problems.
Dec 22, 2010 | Rinnai Water Heaters
Have a poulan chainsaw that won't idle/stay running and bogs down when you press the trigger control. Do you need a certain wrench to adjust carb??
no carb ajustment is done with a flat head screwdriver, first i would remove the card, disassemble it and blast it with compressed air because its probably just clogged up with varnish. to ajust the high low and idle screws bottom both out ( turn in all the way) then unscrew each one turn. from there start the saw and loosen in 1/4 turn at a time until it runs well
Apr 25, 2010 | Poulan Pro Chain Saw 46cc 20"
Mondeo 1.8 y reg petrol. My car wouldnt start after leaving for a couple of weeks. When trying to start there was a clicking sound. I got some jump leads and the car started first time. i charged the...
Sounds like you have a loose connection on a battery cable. loosen the bolt and pull off each end and clean, then replace. When you clean them, make sure you get down to clean metal.
Mar 26, 2017 | 2001 Ford Focus
Need carb h/l ajustemts and idle controle ajustment
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
May 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
